Las Vegas Evo's
Old May 4, 2008 | 12:01 AM
  #45061
Tunerhead's Avatar
Originally Posted by teribble
Hey i should be getting my EVO in july!! just wanted to say hi. I live in pahrump and will be daily driving it to vegas. Am i crazy?
Nall......my ex-girl will be doing that commute (from pahrump to vegas) everyday in about a couple months when she moves out there.
Old May 4, 2008 | 12:02 AM
  #45062
Tunerhead's Avatar
  #45063
Tunerhead's Avatar
  #45064
Tunerhead's Avatar
Old May 4, 2008 | 01:30 AM
  #45065
calilancer02's Avatar
laggy inet? ^^ hehe
Old May 4, 2008 | 02:25 AM
  #45066
monkeyevo's Avatar
seibon oem cf hood still for sale 320 $ firm take it !
thanks guys
Old May 4, 2008 | 02:51 AM
  #45067
monkeyevo's Avatar
hood need to go ! guys
Old May 4, 2008 | 10:43 AM
  #45068
Tunerhead's Avatar
Originally Posted by calilancer02
laggy inet? ^^ hehe
no ****ty evom servers last night.
Old May 4, 2008 | 02:28 PM
  #45069
ohsobaked's Avatar
i have the viper 5900 installed on my car and i have an hks turbo timer that has been sitting in my back seat forever! does anyone know how to hook it up successfully cuz i hear its a pain in the ***. Please and thank you.
Old May 4, 2008 | 02:54 PM
  #45070
awd_ftw's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=343306
Time to sell the Evo unfortunately. Two wheels and a cheaper car/truck are calling my name.
Old May 4, 2008 | 06:21 PM
  #45071
For a fuel pump install, is there an access port under the seat (for awd) or do you have to drop the tank to do this..Also are the plastic lines really fragile under there or can it easily be done on the evo in my garage?
Old May 4, 2008 | 07:31 PM
  #45072
evolsk8r's Avatar
Fuel pump is the easiest mod to install on your evo. Take the back seat out(bottom portion. Look for the 2 tabs in the front of the seat to release it),and the pump will be on the driver side. Take the black cover off and you will see the top of the pump. Unplug the wires for the pump, and the fuel line. Careful not to spill gas everywhere. It's a little tough getting the pump out, but just keep turning it back and forth until you find the sweet spot for it to pull out. Then just take the old pump out of the plastic holder and snap the new one in its place. Replace the filter if you got the kit that comes with a new one. Otherwise, just reuse the old one since your car isn't that old.
Old May 4, 2008 | 09:17 PM
  #45073
Nice thank you
Old May 5, 2008 | 04:48 AM
  #45074
BiFfMaN's Avatar
You could just sell the HKS turbo timer because the alarm should have a built in one.
http://www.viper.com/Products/Produc...?ProductID=103
But here is a pin out if the ECU if you still want the HKS one. Find someone that has installed it before..hacking the wrong wires can cause loads of problems.
http://roadraceengineering.com/evo/t...-ecuwiring.htm
And here is a install instruction...but for the Greddy. Turbo timers all hook up the same.
http://evomoto.com/tech_info.php?tPa...c4c198d0058401
My suggestion is always buy a Jumper cable so you can hack that up instead of your OEM wire harness.
Old May 5, 2008 | 04:51 AM
  #45075
BiFfMaN's Avatar
Enjoy
Dont do it with a full tank..and use alot of towels to cover up the interior....yes there will be blood!!!...er i mean Fuel.
And bleed off the pressure on the fuel lines.
