Las Vegas Evo's
Old Apr 23, 2004 | 05:04 PM
  #1336
evilevovegas's Avatar
Lol little wing high car, cant make meets damn alex.
Old Apr 23, 2004 | 05:07 PM
  #1337
evo81's Avatar
Originally posted by gonzo
Great, I'll be the only evo in the group in 4x4 mode.
off road time gonzo you GB on them tails is almost full.
Old Apr 23, 2004 | 05:20 PM
  #1338
vegasboy301's Avatar
going to go get them now. stick to the plan corey.
Old Apr 23, 2004 | 05:21 PM
  #1339
Rowdy's Avatar
LDL tonight at 6pm anyone?
(Bringing camera anyway).
Old Apr 23, 2004 | 05:33 PM
  #1340
dank's Avatar
whyd you cancel the stage one jon, something that i need to know about since i ordered it from the same guy. i cant even get in touch with the guy to know if it has shipped or not yet.
Old Apr 23, 2004 | 05:39 PM
  #1341
So dank i didnt know you had an evo 3, whered you get that?
Old Apr 23, 2004 | 05:48 PM
  #1342
dank's Avatar
hmmm, thanks for pointing that out... fixed it now
Old Apr 23, 2004 | 10:42 PM
  #1343
gonzo's Avatar
disgrace
Old Apr 23, 2004 | 11:27 PM
  #1344
low rider, lowrider.
Old Apr 24, 2004 | 12:57 AM
  #1345
SinCityEvo's Avatar
Gonzo, I am stock height, but will be ordering springs soon. Corey, you have another one to do.
Hey, did a search and those with springs are getting a new alignment. It may be slightly off in the camber. Don't wear out your tires on the inside edge. You guys know an alignment shop where we can get a good deal?
Old Apr 24, 2004 | 01:27 AM
  #1346
Rowdy's Avatar
Theres a place over by that one day/maaco/whatever, paint shop on Valley View between DI and Sahara, (its actually behind it on a smaller street).
$40 bucks is what they charge for a front end alignment on any lowered Honda.
Sorry to be so non-specific, but thats the best deal I know of on alignments.
Old Apr 24, 2004 | 07:01 AM
  #1347
evoguy's Avatar
don't pay someone to adjust your camber, just do it yourseld it's uber easy! The peoples who are off when they lower them are just missing one minor step in the install.
Old Apr 24, 2004 | 07:02 AM
  #1348
evoguy's Avatar
By the way the reason I know is because I missed it and had to go back a couple days later and fix mine.......
Old Apr 24, 2004 | 11:36 AM
  #1349
SinCityEvo's Avatar
Well, tell us the step.
Thanks, Rowdy. Will prolly have it aligned for the hell of it. It worth paying 40 bucks versus 200 per Advan.
Old Apr 24, 2004 | 12:20 PM
  #1350
evoguy's Avatar
On the 2 bolts that attach the strut to the rotor assembly, the top bolt has an arrow on it. If it is pointing inward (i believe) camber will be normal -.8 degrees, if it points outward you get more camber -2 degrees. It is a 180 degree adjustment (ie: turning the bolt) thats all there is to it, just make sure both sides of the car are the same. If you chose more camber, you will corner like a slot car but tear up tires. This is the same adjustment an alignment place will do and alot of them don't know about it. I had to research it and found an illustration on this forum.
You can also change the camber in the rear. I have experimented with it but put it back to almost stock settings, This is also easy as all you do is loosen a bolt and slide the bottom of the tire in or out as you see fit. This adjustment is a slightly harder than the front since it moves quite a bit and the front only has 2 settings.
Attached is a pic of the bolts in front I was talking about.....
