Utah Evos
So did you switch to the other ecu from the 9694011? I have been working my *** off at work, so I haven't had a chance to play with switching yet. Does the newer programing have a higher load limit? (I think 9694011 tops out at 280 or something, but I know the newer IX ECUs go to like 320 or something). I still need to look into all that.
Deal.
And hey, don't be making fun of me!
Is Josh the guy advertising on KSL? He's 22 and he's trying to offer tunes on people's cars?
I have 4 Yokohama's that you can just have... lol
What brand of LICP? I may want it from ya, I'd like to get one before I start doing my ECU boost control.
You can scale out your tables
and a good idea when running high boost. I'm going to switch over to the edm 96530006 tephra mod v5.10 Josh helped me tweak and clean up my xml files, I haven't flashed it on the car yet cuz I thought I'd wait for Josh to show me ecuboost etc. I'm not a hord with my map **** I'll send ya everything I got and you could just tune your car from that...it's prob a little too aggressive for your car but it's all setup with scaled and tephra mod etc
Want me to bring up the LICP??
Very nice!
Got his info? (email or something?)
Michelin Pilot Sport PS2 255/40/17
I just need one.
Josh, you could do the basics easy I bet. The sti's use ECUFlash for the tuning and a different program to log that shouldn't be too hard to learn. Jake prob doesn't need anything too hard, just something to clean up the stock map like the evo's. Probably just timing and fuel to make sure it doesn't knock, makes good power, and gets good mileage.
Free is a very good price. What kind, what size, and how much is left on them?
I just need one.
The newer ones do, atleast the 06+ R6 does. You should see how big and ugly the damn thing is, plus it has a throttle activated blutterfly valve between the cat and the can. The cat delete alone is supposed to shave like 10lbs off the bike. Ill take some pics when I remove it to show how rescrictive this bisch is. When I'm done with it, it will just be a header into a straight pipe and I will just tinker with the tuning to adjust for the lack of back pressure. So far thats the plan anyway.
I was just giving you ****
I remember his name was Josh.We are using the mac valve for a solonoid right?
You can rescale the Load & RPM axis to whatever you want..I just scale them a little higher than what I hit with load...if I hit 280 I'll scale to 300. I have been on this ROM for a while...If you have any problems I can help you out.
And I'll get the wheels when you buy em for me. For now, the BBS are great.
Deal!
That thread on nasioc got even crazier. One mod even referenced back to the same thread that talks about Mobil 1 being good... again. And someone says that 10w-30 isn't good enough for Utah
Is the Subaru motor really that finicky? I really find it hard to believe the dealer uses oil that can cause blown motors and spun bearings.
PS, anyone notice EvoM going down a bunch?
I'll get his work number for you or just talk to him...what size man?
