Utah Evos
Old May 2, 2009 | 07:26 PM
  #24376
DIDYSIS's Avatar
Ya I know that. Sometime I want to come off meth I think. Maybe, not sure, depends what i can get out of it. I just run washer fluid now so 33 percent. getting some real stuff soon though, Ill try it out and see if I get any difference, well Im off later all,
Gear let me know if we can still hook up or not, KEVIN
Originally Posted by wesside
it's not just the $ factor it's also doing it safely the dds3 setup is great failsafe which shouldn't be done without it and it goes so nicely with the alt-map switching
imo it's better to spend that extra cash...as I've been told since a kid "ya get what ya pay for"
Old May 2, 2009 | 07:30 PM
  #24377
sikwititevo9's Avatar
Hell yea you could make some decent power and you can run the 880cc injectors I would suggest a meth kit though so you can run 28-30psi range
or could do E85 but go bigger with injectors if you went that route
well wes if i put everything on i would need you to help me with a slight tune or something to get me going til i get it tuned. what do you think?>
Old May 2, 2009 | 07:50 PM
  #24378
wesside's Avatar
WTF!! Your running washer fluid...why are you doing that? all those detergents aren't good...buy some meth from where ever Jason gets his. I've still got 2gallons left but I'm going to be in need soon, I believe Jason gets his from Haycock..? I was going to see if I could snag a gallon or two from him or I do have a 5gallon pale I could get filled up
Real methonal yea your going to notice
Old May 2, 2009 | 07:53 PM
  #24379
wesside's Avatar
When you get everything figured out on what your going to do and installed then Josh & I can help you out, if you wanted to buy a meth kit I can get it for you and Josh & I could tag team install it n get car tuned. Whatever you wanna do, you can always pm me
Old May 2, 2009 | 08:11 PM
  #24380
Evolution IVGSR's Avatar
Originally Posted by MRevolutionIX
does anyone know if the lap battle event is still happening today?
Yep it happened today and was fun. I was there. Up at
5:30
Fairclough who did your tune??
Criddlen his name is Nate.
Timmay that wouldn't cause your bov to stay open though
meth + boost= happy turbo & no worries about where the E85 station is at or draining the tank or what not to switch to 91 map haha
I don't have to worry about my area because there is like 5 now 3 are with in 10 miles of my house and One is about a block away
I want to be at 600+ well race boost you know, but you know I am sure I will be able to push over 550 and that will make me a very happy man.
Gear good to hear from you, so you think its worth to block it or not I mean in sure weight I will save maybe 3 grams.
Skit- should be around 450.
I would love to have a Crazy high HP car, but I honestly want something around high 500's thats good enough for getting in to the 9's with a good driver.
man I got so much stuff I want to do to my car, later I want a 4088. or just a 42R, Ya I need more fuel pumps even with the tons of meth I dump and what.
haha That would be sick but I don't think I will ever go any bigger than a HTA 37R Thats what I would love to have and make over 750
Old May 2, 2009 | 08:32 PM
  #24381
gear head's Avatar
I was going to port mine but got lazy. I hear no real power pains till around 500+ but as I said before one more hp still is one more.
The gains will mostly be in the form of throttle response.
Old May 2, 2009 | 08:36 PM
  #24382
gear head's Avatar
Not yet, still waiting forr booster to give me a call back..so not looking too promising.
I run HEET in my system
Old May 2, 2009 | 09:54 PM
  #24383
wesside's Avatar
That's what I'm talking about
Old May 2, 2009 | 10:36 PM
  #24384
TwoFour's Avatar
**** Vista! I upgraded my Evoscan and now the damn serial to usb converter wont work again haha
Old May 2, 2009 | 11:29 PM
  #24385
DIDYSIS's Avatar
ok let me be more specific, I run only certain types of washer fluid. Some do have detergents in them and if you shake the bottle you will see it get really soapy and stay like that for a while. Then take your Peak -20 fluid and give it a shake and you can see will make the air bubbles from the shake then they all go away in seconds. thats what we call pure meth and water. of course its only 33 percent meth 77 water but you know its not bad at all, and from sams club you can get 6 gallons for $9.54, Cheapest find yet!! 1.60 a gallon, Walmart has it in winter months for like 1.62 and I found that Target has a good mix type for around 1.67ish. Other stores like most auto places carry it for around 2.00 a gallon, I know know 50/50 but still good stuff. -25 is 35 percent and they have it at some places but that 2 percent is like nothing for buying it at 7 eleven for 4.50 a gallon. Of course real meth I am sure is best but also running how i do makes it so my car is not fully dependent on the stuff. But i can tell a difference with and without. Air Fuel does not lie. I should have 20 gallons by next week, if you need some let me know and I can sell you a little. But mostly I plan to use it all. Well of course that is if I see that its really better. I hope it is.
Old May 2, 2009 | 11:37 PM
  #24386
DIDYSIS's Avatar
Ya I sometimes wish mine was a 37 but I think I will be real happy with the 35R, I hear/read that that HTA 35R make very little less power than a normal 37R, but who knows really depends on car etc, I figure if I get something again might as well go crazy all out.
5:30
Old May 2, 2009 | 11:55 PM
  #24387
ikon busta's Avatar
some pics out in the rain today.. i have some more but its having a hard time uploading them
Attached Thumbnails Utah Evos-dsc01996.gif   Utah Evos-bath.jpg   Utah Evos-blackandwhite.jpg
Old May 2, 2009 | 11:56 PM
  #24388
wesside's Avatar
So your getting 20 gallons (half drum) ? of 100% pure methonal? Just wanna clarify
Old May 2, 2009 | 11:57 PM
  #24389
wesside's Avatar
you using 2.5?? and **** vista
  #24390
DJ Brett B's Avatar
I would be worried about long-term use of washer fluid as opposed to using pure methanol mixed with distilled water. They use regular tap water when making washer fluid, which in unfiltered and has mineral deposits in in that over time may lead to clogging of the methanol nozzle. I think its called Jensen's Oil off Redwood road that sells 5 gallon drums of methanol, I just bought one there for around $30 and a big jug of distilled water from the grocery store for $2, I'm running about 3/4 meth and 1/4 distilled water.
