Utah Evos
Old Aug 13, 2009 | 05:28 PM
  #28261
Jay644's Avatar
Yea, I'm doing the water pump, tensioner and all the pullies. The how-to I read looks like a real PITA for someone with just regular tools. But in that thread they said it only took 3-4hrs between the two of them on their first try and only 2-3hrs on their second car.
Old Aug 13, 2009 | 05:31 PM
  #28262
wesside's Avatar
Originally Posted by sikwititevo9
are you just doin water pump and timing belt and tensioner? are you not doin any head work or anything?
aah fun stuff I'd offer to help if it didn't just basically do it twice recently FTL..DIDYSIS helped me setup my timing belt and that's the part I think sucks but he's got the system worked down pretty well
Old Aug 13, 2009 | 05:32 PM
  #28263
wesside's Avatar
Originally Posted by Jay644
Anyone know a cheap place to do my 60k? I'll be buying the parts from RussellM. Solid quoted me at around 500 but I'm not sure if they knew I would have the parts already, it was a while ago I spoke with them. Should only be a 3-5hr job, right?
Do it yourself and have fun
Old Aug 13, 2009 | 05:33 PM
  #28264
Timmay81's Avatar
i hate not being able to drive my car
Old Aug 13, 2009 | 05:46 PM
  #28265
DIDYSIS's Avatar
I bet you would not even want to do it your self
  #28266
Jay644's Avatar
I don't trust myself enough to do the timing belt. Nor do I have the patience anymore to do something like this.
Old Aug 13, 2009 | 05:52 PM
  #28267
sikwititevo9's Avatar
we did my buddy erick's evo just a couple months ago and it only took us about 3-4 hours to do the timing but it took a week to actually finish it. he took the head off and had it ported and did the whole works. valve train and cams, cam gears, you know where im goin
Old Aug 13, 2009 | 05:53 PM
  #28268
DIDYSIS's Avatar
Ya trust me Timing is something you need to be exact about, ask WES he knows well whats going on when its wrong, cars just don't work. I helped him set his the other day. As for time, I mean its a good job, it was take you a good while to do it. I think most of all that was them just doing the timing that took them a couple hours. Let me know, am well versed in all those areas of work. KEVIN
Old Aug 13, 2009 | 07:06 PM
  #28269
Jay644's Avatar
Did you two ever figure out what cause for his timing being off? I know you guys were able to get everthing back in order, just curious to know what the cause was.
Old Aug 13, 2009 | 07:15 PM
  #28270
DIDYSIS's Avatar
Seemed more that they used the timing gears to make the timing work, rather than doing it right and then adjusting with the gears. Ask Wes though he might have more info for you, I was only fixing the problem not in the making :-)
Old Aug 13, 2009 | 07:49 PM
  #28271
wesside's Avatar
Timing belts not on my list of things to do I'd much rather do something else
Yep I wanted someone who knows more about evos help me rather then just another hand there thanks for your help. I had only setup two timing belts/timing on two motors with them out of the car and thanks again for the help sucked I put it together and well then back and together again after that
Well it started with some bad gas and some knock..I was replacing my valve cover gasket and while the valve cover was off a friend moved one of the gears and possibly the exhaust adj gear was loose and slipped or well anyway the timing moved..So without a tensioner tool used the adj gears to make back top dead. I got a threaded bolt and went to zero out gears and put back to top dead cuz well that's how I am. When the threaded bolt(homemade tensioner) broke down inside so had not choice but to take everything all apart to get out broken bolt and might as well setup timing all fresh. So if that makes any sense to you at all
off topic..I want to see the new Final Destination movie Aug 28th
Old Aug 13, 2009 | 07:58 PM
  #28272
DIDYSIS's Avatar
Well at least the car is going good now,
Timmay whats wrong with your E85 Hot rod??? Or are you just away somewhere
Old Aug 13, 2009 | 07:59 PM
  #28273
DIDYSIS's Avatar
Also side note, saw another red Evo, black wheels, chrome lip right around 7200 and I-15 I was getting off the freeway and you were still on
Old Aug 13, 2009 | 09:55 PM
  #28274
TwoFour's Avatar
I need my 60k done too, (pay someone to do it) danggg! need to buy the parts first. So those 3 things you should change??
Old Aug 13, 2009 | 11:34 PM
  #28275
wesside's Avatar
Originally Posted by ikon busta
wow i havnt been on for over a month... utah evo's has its on mod now? did jake ever have his pool party? and im selling my car probably in the next couple weeks, i needs the money to move
****ty bro Not having an evo would probably save alot of ppl alot of $ BTW I don't have your # anymore man so throw me your # again
