Utah Evos
Old Mar 13, 2008 | 12:57 PM
  #13156
UT_Evo's Avatar
Yeah, first time I swapped out with Scott (the creator of this thread) for a day since he had an extra hi-flow. And swapped back RIGHT after. Then the last emissions/inspections I bought a hi-flow to make selling the car a little easier too. Put it in and left it in till about 2 months later when I sold it. But it is uber easy to swap out as long as you remember to put something under both sides of the tbe so it doesn't fall down
And Jason's idea may work, they just do a visual inspection. My car passed the sniff test, near the high end of pollution, but still passed when I did it with a test pipe.
Old Mar 13, 2008 | 01:05 PM
  #13157
jbeck's Avatar
Originally Posted by Fairclough
Just put a heat shield around your test pipe, if it doesn't pass they will give you 15 days to fix it.
thats what i was thinkin of doing but i don't know how to weld also been thinkin of finding a cheap hfc and just guttin it out
Old Mar 13, 2008 | 01:20 PM
  #13158
jbeck's Avatar
So if i had an o2 spacer on, do think they would know what it was?
Old Mar 13, 2008 | 01:25 PM
  #13159
evobeatsti's Avatar
i have an o2 sensor spacer, no cat no crash beams and a few other things and i still passed the emmissions thingy that you have to go through every 2 years or whatever
Old Mar 13, 2008 | 01:27 PM
  #13160
UT_Evo's Avatar
Alright... so gloss black it is...
https://www.evolutionm.net/forums/sh...d.php?t=330153
Hawtest ****ing car evar!
Old Mar 13, 2008 | 01:58 PM
  #13161
mdinubil's Avatar
all black is my favorite for shoa....
Old Mar 13, 2008 | 04:43 PM
  #13162
evobullet's Avatar
I remember seeing some one who made a test pipe that had a cat housing welded to it but i cant remember where it was
Old Mar 13, 2008 | 04:57 PM
  #13163
jid2's Avatar
I went through emissions testing 2 times in Utah with my test pipe and the stock heat shields welded on over top! They plug into the the OBDII for the sniff, so as long as you don't have a CEL you are good.
Old Mar 13, 2008 | 05:40 PM
  #13164
evo_domination's Avatar
Originally Posted by jbeck
Cuz most likely a cant pass emissions with a test pipe on and i've been looking forever and the one i want is finally on sale. Anybody know if you can pass with a test pipe?
I looked under the car today and it doesn't look like the oem cat is even on there, some after market i guess? But my CEL is on so most likely that means the cat is broken, doesn't it? Or could it be something else?
Perrin Performance makes an o2 eliminator for the downstream o2 sensor. It eliminates it all together and sends the proper feed back to the ecu to keep the CEL from coming on for that reason. I do my safety/IM in davis county even though I live in utah county. All they do is like JID2@Binary said. If no CEL, you pass. I put my cat on just incase someone wants to do a tamper-test. I run my test-pipe 90% of the time.
I got on your buddy's site and the last thing i did was check out the customer car of the month
Does he have an actual location or is just an online thing?
No. He is just online for now. Just uploaded all of the cams to his site right now. But he does have some under the table deals on Brian Crower Cams for cheap if you pm me.(so he doesn't get in trouble through his vendor)
Old Mar 13, 2008 | 08:10 PM
  #13165
Evolution IVGSR's Avatar
Originally Posted by evobeatsti
i would be so stoked to see joes nsx, maybe ill go down a lil early just to stop by the shop and check it out. you should also talk to adam and erich and all those other guys down there, maybe alllen zou, or brandon w/ his rattle can sti, or is it brandon who has the 800whp skyline and the silvia daily driver?
Well Brandon and Joe are going to be at the track (test and tune day) So I don't think they will make it. I doubt that Erich or Adam will come out they are panzies Allen Doesn't have a car right now just a big SUV and I may be able to get Brandon's HOT ROD BLACK STI out and Seth is the one with the 700WHP Skyline and it getting some more work done to it I may try to get him out in his Porsche turbo for Jake
Old Mar 13, 2008 | 08:15 PM
  #13166
UT_Evo's Avatar
Hey, then maybe we can actually gang up on the Evos... Maybe...
Old Mar 13, 2008 | 08:43 PM
  #13167
Jake the new GT2 is Sooo Sick I want one one day when they are 20 years old and I can afford one though :LOL:
Old Mar 13, 2008 | 08:45 PM
  #13168
I saw that Jake! Hater!
Old Mar 13, 2008 | 08:48 PM
  #13169
Dallin, do you have instant messenger?
Old Mar 13, 2008 | 09:49 PM
  #13170
evobeatsti's Avatar
hey are you still interested in the tires? can you bring the money on saturday like we said?
