Works Aperture Gains Documented?
Difference I noticed at Sears Pt going from stock TB and downpipe-back exhaust to TB + full TBE (catless in both cases):
- smoother continuous pull in the upper rev-range
Basically it made the car feel a bit more like a well tuned NA car in the upper rev-range (which is why I could pass E46 M3s).
Well I dynoed yeserday and I made a few peak hp less than when I had the stock throttle body.
That sucks, but the hp and tq lines smoothed out and I did pick up about a few hp between 3-4000rpm. After 4000rpm, the hp and tq remained almost identical to my last dyno run but had slightly less numbers. This could be from numerous variables, but all in all I am happy with the aperture, but probably wouldn't buy one again unless I was hard pressed for wanting to buy something for the car.
Bottom Line from my experience with the Aperture is this
1. smoother power delivery
2. picked up a little on the low end
3. lost a little on the high end (I have no idea why)
4. peak numbers fell
That sucks, but the hp and tq lines smoothed out and I did pick up about a few hp between 3-4000rpm. After 4000rpm, the hp and tq remained almost identical to my last dyno run but had slightly less numbers. This could be from numerous variables, but all in all I am happy with the aperture, but probably wouldn't buy one again unless I was hard pressed for wanting to buy something for the car. Bottom Line from my experience with the Aperture is this
After reading my post, I just want to clarify that the runs were done on different days with different octanes? 94 vs 93. Also to note, I have logged about 5000 miles since my last dyno and my most recent dyno, so that could account for the slight decrease in peak numbers. All in all the aperture has given me a smoother power delivery and should help in the long run once I start adding more mods.
Originally Posted by EM@WORKS
Stock throttle body vs. WORKS Aperture (original) on the same day with no tuning changes.
In case you can't read the text, stock peak was 229WHP vs. 237WHP and there is smoothness over the dips.
shiv
I'm not sure why you are posting in our forum but yes, my HP scientific calculator confirms your math. 60 enter, 23 subtract, = 37
I wish our R&D procedure here at WORKS was not as tedious and thorough either. You should have seen how crazy the rest of the day was!
But we have to do it properly or not do it at all.
Regards,
shiv
We tested 5 different product configurations that day and would love to give you the play by play for every run with our notes and data.
We have never deleted your questions. In fact as a general rule we don't delete threads and posts like some 'others' do because we have nothing to hide. We sleep well at night.
The moderators have repeatedly deleted competitors posts in our forum in the past because they believe it is inappropriate as do we.
That is why you better hurry and get your jabs in before...
That's all we have to say. Please let us get back to our customers and doing R&D. We simply don't have the time.
mrm95
Jan 2, 2014 03:18 PM
IX_MR
Mar 5, 2012 12:50 AM
