The Official WORKS Brain Flash Dyno Plots!!!
Originally posted by Boeturbolancer
After seeing the evo and sti head to head by variouis car mags i'd still agree that the evo is overall better. Only thing is the lancer interior wish they went different there. As for the ecu mod seems really good to me. I wouldn't think they would do AF ratio at 10 rather more like 11.5 even 12.0 with 19/20peak boost. Rev limit to 7850 seems about right for the vlv springs. Much higher and you may experience some floating which could kill the motor. I have seen one reflashed ecu for evo running fuel at 12.2:1 and 22peak boost across powerband and 7800RPM limit. Let me just say that there is 40hp unlockable in the car. One reason i'm seriously debating getting one. I've personnally seen the evo at the track and with the ecu upgraded i believe high 12's are possible. Definately do CAI/exhaust/boost upgrades before doing ecu. That way you won't have to return later unless you get real serious. With those mods you'll be low 12's no problems.
Edit: nice work Dave, you can see the conservative side of the graph... i'm curious to see a more aggressive scale including intake/exhaust mods. Those are the two things everyone will do without a doubt so why not work ecu for that? Also get a more aggressive pull which still allows for minor fluctuations in octane. Keep up the endeavor as the evo guys are loving this!
That exhaust upgrade you asked about, they do flash for exhaust upgrades. And they flash for their products. I don't recall seeing a boost or CAI upgrade, but there is an exhaust/throttle body upgrades.
and you right, the Evo guys are loving this...
Originally posted by Honky
Hi David,
Please don't take this the wrong way but I have a couple of issues with your dyno results. You mentioned that you used an AWD Dynojet. Presumably a dyno in the SF Bay area where I just happen to live
However, I have never seen a stock EVO dyno as low as 202 wheel hp on any AWD dynojet. In fact, just about ALL of the EVOs dyno'd on AWD Dynojets have made 220-240 wheel hp. Even on 91 octane gas. Can you explain this?
Also, why is the hp/torque graphs so rough and lumpy? This would, in my opinion, indicate poor tune and/or knock sensor activity. A properly tuned engine should work like an efficient pump and exhibit power curves consistent with its natural volumetric efficiency. With the dyno results you've presented, all I see is a poorly running stock car an even more poorly running modified car that just happens to make more power from presumably running leaner with more ignition advance.
Again, I'm not trying to bash the results. But I'd love to engage in a conversation with one of your engineers.
Best Regards,
Honky
Hi David,
However, I have never seen a stock EVO dyno as low as 202 wheel hp on any AWD dynojet. In fact, just about ALL of the EVOs dyno'd on AWD Dynojets have made 220-240 wheel hp. Even on 91 octane gas. Can you explain this?Also, why is the hp/torque graphs so rough and lumpy? This would, in my opinion, indicate poor tune and/or knock sensor activity. A properly tuned engine should work like an efficient pump and exhibit power curves consistent with its natural volumetric efficiency. With the dyno results you've presented, all I see is a poorly running stock car an even more poorly running modified car that just happens to make more power from presumably running leaner with more ignition advance.
Best Regards,
Honky
"Just so you know..... [their] DYNO ACTUALLY READ THE SAME CAR (1WRX2NV's Vishnu stage 2 WRX) 7HP LOWER than Shiv's Dyno Dynamics setup. So keep this in mind when passing judgement."
As far as the look of the graph, that's just how a real dyno chart looks. You can smooth them until the cows come home, but we wanted people to see what was actually going on so that they could get a real sense of the substantial improvements WORKS has made in our extensive development of the Brain flash. We have not only dyno'd our own car, but other cars as well, and the peak power and look of the graphs -- under similar conditions on the same dyno -- were nearly identical.
-- DavidV
I know that you guys are busy, but whenever you get the chance I would love to see a pull with 93 octane, an intake and an exhaust. Reason for this combo would be that it is something that we could do while still keeping our factory warranty, as it seems that this is the most that Mitsu will let us get away with. I for one am not willing to give up a warranty on a brand new car but I would still like to see what kind of power I could get out of it.
What I meant was, maybe from all the WRC and EU spec cars, we can actually maximize the power output of our EVOs safely. Yeah, 8500 rpm is high, but how about 8000? I threw away 8500 because I saw an EVO reflashed ECU with a "claimed" 8500 redline on EBay (who knows how true it is). Also, I personally think that 19 psi max is VERY low. At least 20 psi tapering to 18-19 psi should be safe and efficient. I also have reservations on the 8.8:1 AF ratio.
I thank WORKS for spending the time and effort in improving the EVOs performance, but I really do think it is a bit thin and needs a little more work. I AM impressed by the HP gains like I said, but like you've confirmed, the TQ is a bit thin.
That's $0.04.
STI
That's $0.04.
STI
I think that there "is" somewhat of a question regarding the availability of the 93 octane map. All of the West Coast tuners have opted to tune to the safe side of things, and have all primarily been pushing their 91 octane maps.
When I originally spoke with David about this issue, he mentioned they were still undecided on how to approach the 93 octane re-flash, if at all.
I understand that access to 93-94 octane pump fuel is an issue out West, and that mixing race fuel to come up with a 93-94 octane mix may not result in precise results.
Altitude and weather conditions in comparison to other parts of the country are also going to make creating a generic 93 octane re-flash for the entire US more challenging. Concerns about people taking there EVOs on a trip from an area that has 93-94 octane into an area that doesn't is also a concern for tuners like Works.
At the end of the day a 93 octane map may only result in an additional 5-10 whp, but personally though I will take that measily 5-10 whp if the choice is presented any day of the week!
On the flip side of that I don't want an unusable map that causes pinging and constant timing retardation in the midwest heat and humidity!
As far as the comments regarding timing and the affects of knock.......sure when you run more agressive timing on crappy 91 octane fuel you are going to see knock, and the ECU will retard timing resulting in poor performance.
At the same time if the timing maps are built around the knock threshold of 91 octane fuel, simply running 93 octane is not going to miraculously recalibrate the timing maps.
BTW Mayhem ..An octane sensor in the gas tank eh?
There are a few folks out there who are new to car tuning on this board, but I hope most people are smart enough to understand the reason for wanting the 93 octane re-flash.....maybe not though? ;-)
I do agree with Boeturbolancer, and am betting that the addition of a few select bolt-ons will push the whp up substantially(40-60whp) as we have seen with RMR's results. It will really be up to the tuners to decide how far they are willing to go with various tuning maps for different mod combos.
In the end all of this is good news and we are fortunate to have as many options as we do! :-)
So 30 hp at the wheels would mean what??? 40 hp at the crank. So the evo being rated at 271+40=311 hp?! That sounds good to me. David at works is sitting on a gold mine right now, if this is a safe way to get more performance out of your evo while having your warrenty in tact. He has always said better drivability and safe performance. He is being kind of tight lipped about numbers, and I dont blame him, he is sitting on a gold mine and dosnt want to give imfo away.
Forget ultra low times at the track, if this ecu flash can provide alround better street performance, and it looks like it does. While having NO PROBLEMS, then he has hit a home run. I just put a ralli art drop in filter in my car the other day and I can sure tell a difference, it pulls freer and the boost comes on faster. Looks like this ecu flash has about 5-6 times better performance than my drop in, just a guess. I think it will get really interesting after a few people put a few miles on thier reflashed ecu's and then we will see thier reviews/problems/issues. Its going to get very interesting very quickly.
I personally think WORKS has a winner here. If its everything he says it is.
BADWRX is wrong. There is a substantial differerence between the two dynos. There are a few issues with the sample car he sited that I won't go into. Let's just say that all things equal (testing proceedure, conditions, etc.,), expect 16-18% difference between Dynojets and our Dyno Dynamics dyno. It's been proven time and time again.
Here's a link to a well-controlled dyno test done a few months ago by a mutual customer both of ours and ATPs:
http://forums.nasioc.com/forums/show...vishnu+and+ATP
Cheers,
shiv
I do not understand when peoplle say that the torque is a bit thin. Yes there is only a max increase of 15.8 ft/lbs (if you can call that only), but at a certain point in the map it is a 25 ft/lbs increase and it come on faster, stays solidly up, and continues much further. I know it may not look like much, but this improved TQ curve will net a good "seat of the pants" difference in feel. I can't wait to see what it does when combined with a few other modifications.
-- DavidV
So david, why dont you tell us how it drives compared to a stock Evo8, that might help some.
Also Shiv, nice write up in this months sport car compact, Your stage 2 wrx kicked major *** all for $33,000 including the cost of the wrx, it stomped the stock sti. I also like the wingless look of your car. good job!
Back to topic: The Stage 2 car in the magazine dyno'd at 255 wheel hp on our Dyno Dynamics dyno and 296 on the AWD Dynojet at HKS the following day. The STi, likewise, dyno'd at 220 wheel hp on our dyno at at ~260 at HKS. So, yes, there is a substantial difference between the two dynos. Anyone who suggests otherwise needs to be more controlled with the testing methods. We go so far as to even log the raw fuel/timing/boost values to ensure that there are no hidden differences between the two tests.
Finally, please forgive my participation in this forum as I know I don't belong here. I just wanted to clear up some confusion that was brought to my attention regarding our dyno calibrations.
Cheers,
Shiv
... exit stage left
-- DavidV
So how many people from evolutionm.net have purchased this re-flashed ecu your sending out next week? I cant wait to hear what they think of it. Reliablity is about one notch above performance gains in my book. Hope everything is as you say. And your time was well spent in developing this ecu flash. Also what tool does the Mitsubishi service people use to check codes in the ecu? You have said all codes are there and you cant tell the difference between this reflashed ecu and a stock one. Can you tell us in more detail about these two issuses? I think it will put many, many people at ease if this is truely the case.
Thanks.
Thanks.
