WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Works Shifter Bushing Compound
Old Feb 15, 2008 | 10:51 AM
chu's Avatar
chu
WORKS guys, explain to me the difference in the WRP Urethane in the Works shifter bushings, compare to regular urethane and poly-urethane. I'm at a cross road on deciding which one to buy! Oh, is there any deals on the whole setup (Shifter base & Cable bushings)
Old Feb 15, 2008 | 01:28 PM
Jamie@WORKS's Avatar
There's a vast array of polyurethane compounds available. We're leaning a little softer than what's used on our WRP suspension components (although significantly harder than the OEM rubber) on the cable/console bushings. Additionally, the process used to create the compound yields fewer air bubbles and a smoother finish, which leads to a more consistent product.
The cable bushings are also unique in that they incorporate a self-lubricating metal sleeve. Without the sleeve, we found that the urethane tends to bind and needs frquent lubrication--and even then isn't as easy to shift as we'd like. Going all metal leaves no give in the system, which can lead to excessive/premature wear on surrounding components. The WORKS cable bushings take the best of each (precision of the metal with the flexibility of the urethane) for a superior product.
We've considered packaging these items, but haven't officially done so. If you're looking to pick up both, we can probably work out some sort of discount
Old Feb 15, 2008 | 02:05 PM
jdeitch's Avatar
I just bought the cable bushing plus the console bushings along with the WORKS clutch hose and grab shift knob and nobody offered me any discount (Not even a decal in the box.)
In any case I think their products are top notch and are well/fully engineered and track tested. The cable bushing and hose will go in with my new ACT HDSS+Streetlite.
I installed the console bushings in about 15 minutes and they made a HUGE DIFFERENCE in my 2005 MR.
Old Feb 15, 2008 | 02:07 PM
Tsurugi-san's Avatar
I smell a coupon for you ^^^^^ . . . .
Old Feb 15, 2008 | 02:14 PM
jdeitch's Avatar
We'll see about that... It would be nice, but not necessary. If their watching this thread I can confirm with my receipt #4168.
I've spent alot of time drooling over goodies on their site. I'll be vacationing up near their facilities later in the year... Maybe time for some EVO goodness.
Old Mar 7, 2008 | 05:43 PM
Davo's Avatar
me too, got the shifter base bushing and also linkage units and no discount
haven't installed but the build is top notch and the best option once u not looking for solid metal pieces for these places
Old Apr 9, 2008 | 03:20 PM
jeffbum's Avatar
I just installed the cable bushings, and the grab shift knob. I thought i ordered the console bushings but im a big idiot and forgot to double check the cart. The bushings went in rather easily, and there is a definite difference. Also i was told by the rep i got the last 6-speed shift knob
Old May 26, 2008 | 07:57 PM
hytek369's Avatar
i would like to purchase both. i tried to contact you but you don't accept PMs. can you PM me? I need both the cable and console. I have the Evo 9 MR (6-speed).
Old May 26, 2008 | 10:16 PM
marksae's Avatar
Does anyone have a picture of the shifter cable bushing installed? Is the cotter pin the only thing that constrains the top half bushing from coming off the cable end?
Old May 26, 2008 | 11:55 PM
cRc`22's Avatar
i think thats a great idea.. ill wait to pick up the 08 lancer short throw if it becomes a package deal since it might sway me if its a good deal
Old Jun 10, 2008 | 07:41 PM
hytek369's Avatar
don't have a picture but just did the install this past weekend. yes, only the pin contrains it.
ryukinevo
May 22, 2015 11:14 AM
bouncintiga
Jan 15, 2010 12:11 PM
JoeyBallGame
19
Sep 15, 2009 11:15 AM
Clipse3GT
18
May 7, 2009 08:37 PM
rcrecevo
Apr 28, 2005 11:09 PM
