WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
StealthWORKS Mufflers.
Old Jul 30, 2004 | 03:17 PM
TylerO@WORKS's Avatar
For those EVO Enthusiasts where exhaust quietness is a strong consideration, the StealthWORKS muffler is your answer. We take the stock EVO muffler and modify it in-house to produce the most power with the littlest noise. We cut open the stock muffler, modify the internals for more direct, unobstructed flow, reweld with stainless steel wire, and repaint to the factory color. Viola, you have a muffler that looks stock, sounds almost stock, fits perfectly, and produces more power. The gains are not as impressive as with the Exhale AB (9HP vs. 12HP) but worth the sound reduction if you're not looking for extra attention. The Stealthworks muffler is 100% compatible with the stock Intermediate Pipe or either of our Exhale IPs. Complete with mounting hardware, new factory gasket, and simple installation instructions.
Here are some pictures!
Old Aug 2, 2004 | 12:52 PM
marksae's Avatar
Do you guys change the inlet pipe diameter also to match your intermediate pipe?
Old Aug 2, 2004 | 08:13 PM
49cent's Avatar
How much? This is what I am looking for.
Rob
Old Aug 3, 2004 | 02:04 PM
It's $199 with a core.
The inlet pipe is the same diameter.
Old Aug 3, 2004 | 02:15 PM
kuniboy's Avatar
you guys just remove the flapper door that's all rite?
Old Aug 3, 2004 | 08:22 PM
marksae's Avatar
Won't there be a neck-down when used w/ your intermediate pipe then?
Old Aug 4, 2004 | 11:07 AM
EM@WORKS's Avatar
We wish it was that easy but no, that is not correct. There is considerably more involved which includes internal welding.
When used with our Exhale IP, there will be a slight neck-down but many enthusiasts are using the Stealthworks with the stock IP which is the same dia.
Old Aug 4, 2004 | 12:05 PM
marksae's Avatar
Perhaps you guys should have 2 versions of the stealthworks muffler.
Old Sep 7, 2004 | 04:42 PM
MBZ16v's Avatar
sound level wise, how does it compare with exhale AB/ARC?
Old Oct 1, 2004 | 04:40 PM
Aby@MIL.SPEC's Avatar
Do you have a before & after dyno chart of the stock muffler vs. Stealth muffler?
I am in the market for a new exhaust, this might be the option as long as I can see some graphs showing the increase of hp.
Old Oct 3, 2004 | 03:14 PM
Jamie@WORKS's Avatar
Sound level is much more comparable to stock (only a hint of difference) than the AB/ARC. HP does jump by 9, but I'll check on getting a chart. These are on sale now as part of our October Exhaust Blowout!
https://www.evolutionm.net/forums/sh...d.php?t=101496
Old Oct 6, 2004 | 08:52 AM
Any luck finding this chart?
What cat was used while obtaining this 9 hp gain, stock or after market? If aftermarket, what size pipe diameter was used?
Thanks
Old Oct 18, 2004 | 01:21 PM
middle of october, any dyno chart finds?
Old Oct 19, 2004 | 06:44 PM
It's one of at least three that's being searched for. Look for a posting soon
Old Nov 1, 2004 | 12:53 PM
Sale is over, being november 1st & no dyno chart.
Thanks
