:helpme: Injen CAI, sudden bucking and stalling
Just put the Injen CAI on my 04 Ralliart. I took it for a drive and filled up on gas. As I was leaving I really went hard on it, hit the Limiter (not entirely intentional) and suddenly the car started bucking around 3k, every gear. i let it idle, it has a hard time idling and ends up turning off half the time, i start slowing down to hit speed bump or stop sign and it stalls. i disconnected the second tube and put the filter on as a short ram and in runs a bit better but still does all the same as above. Its dry out so i know i didnt suck any water up, Occasionally it does backfire through the intake. i get the feeling when i redlined i managed to jump time and bend an intake valve im not sure, any thoughts? Everything is stock too, no other performance parts on the car. Plugs were done about 2k miles ago along with the valve cover gasket, i have a delphi MAF/IAT (i have the stock one that might still be good if that might be the issue) and i have been having CEL for p0113 (Intake air temp circuit a too high) but this is the first time the car has done this. ive had a short ram on the car since i bought it (came on the car already) and has ran fine, the IAT code just started about a month or so ago and the MAF/IAT didnt fix it either.
tsidrift1
63
Oct 9, 2016 02:26 AM
m.s.p
Lancer Engine Management / Tuning Forums
May 8, 2012 02:25 PM
