Shifter Question
Shifter Question
Hello guys, been away from the forums for a bit. Is it just me or the forum has died down. It seems like the for sale section is absolutely dead. Feels to me like a dying platform.
Now for my question. I have a TWM shortshift on my car with the bushings and all. My problem is when Im in neutral if I move the shifter either to the left or right it doesnt come back to the center. I remember installing only 1 of the 2 shifter linkage bushings because the 2nd one was a PITA to get to. I did realized that the oem bushing that I did not change is now loose. Would replacing that solve my problem?
Thanks
Thanks
Lurking from the Evo X side ... If it's not the original bushing, it's probably worth contacting TWM. Someone had a similar issue with an Evo X and TWM responded. In the end they suggested using a lot of grease and said that their bushings will eventually wear into place and the lever will start coming back to center on its own. Don't know what the outcome was, though.
https://www.evolutionm.net/forums/ev...l#post11388542
MSTR MR9
Oct 27, 2006 12:04 PM
swhskenr
Lancer Tranny/Drivetrain Tech
Nov 10, 2003 08:34 PM
urbanknight
13
Oct 1, 2003 02:05 PM
