DOHC for 4g94 engine
Old Jan 30, 2004, 05:02 AM
munkiboy's Avatar
Question DOHC for 4g94 engine
Something I would like to do to my car before I install a turbo is replace the SOHC head with a DOHC head. Anyone done this or know of a way to do this?
Old Mar 13, 2004, 07:59 PM
Viciouz's Avatar
i dunno... i am searching myself... good luck
Old Apr 18, 2004, 01:53 PM
adamntncowboy03's Avatar
Anything is Possible
Hey monkiboy, i already asked if i could use the Dohc head off of the 2.0 Evo and everybody told me it couldnt be done. I have this friend that blew his Sohc head on his neon and nobody said the Dohc on the other neon, probably rt, would fit and he said it went right on with ease. I think nobody would know unless they actually try it. First thing i would do is look at the dimensions of the block and head and do some comparing. I think those japanese guys are always two steps ahead of everybody else. Theres bound to be a head out there for a substitute. If you do find one though let me know, or im just going to port mine out secretly. Thanks, Dusty.
Old Apr 18, 2004, 08:05 PM
Mivec's Avatar
The work and cost involved in this conversion out weigh the benifits. You could use a 4G93 DOHC head off a 97+ engine and then start playing around. The 4G63 DOHC head will not fit onto the 4G94 SOHC block. If you have a closer look the 4G94 SOHC uses the almost the same head as the 4G93 SOHC. I hope that has helped
Old Apr 21, 2004, 10:55 PM
chowetime's Avatar
as well as making sure that all of the water cooling holes ect on the inside of the motor match up as well other wise you could be in for some very expensive repairing
Old Oct 5, 2011, 11:41 PM
CE_GSR1.8's Avatar
ill be doing this conversion myself soon. 4g94 short block with forged rods and pistons with 4g93 dohc heads. Ill be uploading any info etc. As well as the build when i get to it.
Old Dec 12, 2019, 04:50 PM
luis argu's Avatar
What timing belt use for this swap?
RobGinSki
Lancer Engine Tech
Jun 28, 2017 04:28 AM
aznalan
Oct 20, 2014 06:39 PM
purpledranktown
Lancer Engine Tech
Mar 10, 2014 05:33 PM
4g64t_dohc
34
Dec 25, 2011 09:42 PM
Spoz2435
Lancer Engine Tech
31
Jul 17, 2010 03:05 AM
Quick Reply: DOHC for 4g94 engine
