Patch: Force OBD Inspection Pass (acamus, mrfred)
#301
I can say 100% that this is the correct settings that will get you to pass emissions in at least Washington State...I went through last week with everything to force pass and failed with to many saying ready. Changed my setting to the above settings and passed this morning with no problems
EV09AWD (May 23, 2019)
#304
#305
Just out of curiosity why in Golden's definition for 59580004 are both the Monitor Available and Passed both labeled as "Read only, Do NOT Change"? I see that in the rest of this thread it's not labeled as that? Also there is no Non-Continuous Availability patch for my rom
Edit: Whopps, thought this was the Evo X section, but my question might still apply
#307
Some more info.
I recently smogged my Evo 8 here in Califonia. E85, 272/280 cams, FMIC, FPgreen, 1kcc injectors, etc. Used the settings in this post: https://www.evolutionm.net/forums/ec...l#post11095091. All I did for sniffer testing was put the cat back on and it passed smog with flying colors:
#308
does this patch work for Evo 10's? I failed the OBDII test but passed everything else. I need Help! My Tags are expiring by the end of this month and this is the only thing that's holding everything up.
#309
Some more info.
#313
smog
Yes it's happening in california as we speak.
Should the periphery bits be set to stock if I'm using the above settings for monitors available and monitors pass?
What if I have a check engine light on? obd check could pass but check engine light means instant fail right?
