Speed Density IPW Drop Out on 96530006 Patch
#107
Below are the three fixes for 94170015. Only try one at a time. Fix #1 is the sum of Fix #2 and Fix #3.
Code:
<table name="SD Stutter Fix Option #1 (Set Over/Under Flag for MAF Signal Averaging Val)" category="Speed Density Programming" address="162c" type="2D" level="2" scaling="uint16"> <table type="Static Y Axis" elements="1"> <data>Stock = 205 For Fix Option #1, Set = 255</data> </table> </table> <table name="SD Stutter Fix Option #2 (Set Scaling Factor for Transition Load)" category="Speed Density Programming" address="1630" type="2D" level="2" scaling="uint16"> <table type="Static Y Axis" elements="1"> <data>Stock = 112 For Fix Option #2, Set = 0</data> </table> </table> <table name="SD Stutter Fix Option #3 (BT -> NOP for DeltaMasterLoadPos/Neg Threshold)" category="Speed Density Programming" address="26778" type="2D" level="2" scaling="Hex16"> <table type="Static Y Axis" elements="1"> <data>Stock = 0x8909 For Fix Option #3, Set = 0x0009</data> </table> </table>
#110
9653 all in one place:
Code:
<table name="SD Stutter Fix Option #1 (Set Over/Under Flag for MAF Signal Averaging Val)" category="Speed Density Programming" address="162c" type="2D" level="2" scaling="uint16"> <table type="Static Y Axis" elements="1"> <data>Stock = 205 For Fix Option #1, Set = 255</data> </table> </table> <table name="SD Stutter Fix Option #2 (Set Scaling Factor for Transition Load)" category="Speed Density Programming" address="1230" type="2D" level="2" scaling="uint16"> <table type="Static Y Axis" elements="1"> <data>Stock = 112 For Fix Option #2, Set = 0</data> </table> </table> <table name="SD Stutter Fix Option #3 (BT -> NOP for DeltaMasterLoadPos/Neg Threshold)" category="Speed Density Programming" address=" 27a0a" type="2D" level="2" scaling="Hex16"> <table type="Static Y Axis" elements="1"> <data>Stock = 0x8909 For Fix Option #3, Set = 0x0009</data> </table> </table>
#111
thanks mrfred and johnbradley for all the input thus far.
i'm on the 9653 with the added xml and still get a stutter no matter what "fix". wondering what could be the cause. i'll be doing some logging in the next few weeks if i can contribute let me know i can help work together to figure this thing out.
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
scheides
Oct 22, 2021 08:59 AM
