BOOSTED TUNING Custom Remote Tune - JDM EVO 8/FP Red on 98 RON
Old May 12, 2015, 10:35 AM
Boosted Tuning's Avatar
Finished tuning the car remotely a couple weeks ago. Car was from New Zealand and had a LINK G4 ECU. First time tuning the LINK G4 but I found it to be a great ECU.
-Stock Block
-Stock Head
-Stock headstuds
-Stock headgasket
-Kelford TX 272 type L camshaft (10mm intake & exhaust lift)
-GSC zero tick Lifters
-FP Red DBB ported & coated MHI housing (with Turbo blanket)
-Turbosmart internal wastegate actuator (18psi spring)
-Curt Brown ported exhaust manifold
-JMF 02 Dump pipe (titanium heat wrapped)
-Apexi N1 downpipe (titanium heat wrapped)
-STM cat delete pipe
-Apexi N1 cat back exhaust
-Custom short route intercooler pipe (wrapped in DEI heat gold reflect tape)
-Custom 4” front mount intercooler
-Tial Q blow of valve (8psi spring)
-Spoolin up C.O.P non CDI
-NGK BR8EG spark plugs
-MAC 3 port boost control Solenoid (same as Grim-speed)
-ID1000 high impedance injectors
-Walbro 255LPH fuel pump
-Link G4 (plug in ecu)
The car had slower spool then normal but that didnt affect the power. We tried a couple things to make it spool faster but to no avail.
Old May 14, 2015, 08:01 PM
Boost Demon's Avatar
Nice work! Only seems to be a few hundred RPM off maybe, but not bad for 500hp.
Old May 15, 2015, 08:10 AM
mrfred's Avatar
The Red has a pretty nice powerband. Is this a MAF or SD setup?
Old May 15, 2015, 10:52 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Possibly the 18psi gate slowing spool? Reds normally ship with a 25psi gate. Looks to be about 300rpm slow..
Old May 17, 2015, 09:57 AM
SD, since its the LINK G4 ECU
Actually, the client ordered the FP 25psi WGA and he installed it and the spool was the same, even after preloading it greatly.
I think it may be the "custom" IC affecting spool.
Old May 24, 2015, 02:27 AM
EvoLunatic's Avatar
That looks like a solid tune
I'm reading great things about Link. When the time comes it will be a tough choice between Haltech and Link.
Have you tried Haltech? If so, which software do you prefer? Sorry for going OT.
Old Jul 7, 2015, 08:10 PM
bawse.c's Avatar
How would you rate NZ 98 Ron vs US 93 fuel?
Old Jul 7, 2015, 10:22 PM
FossilAus's Avatar
It would be same quality to what we have here in AUS, 98RON = US 93
FWIW 500hp = ~370kw, that's a solid 70-80kw (~100hp) higher than what anybody else in AUS has achieved on pump gas with a Red. The tuners out here must be doing something horribly wrong LOL
Old Jul 8, 2015, 03:24 AM
bawse.c's Avatar
Yeap you are right about the power level. No one here in NZ can produce the same results either.
Old Jul 8, 2015, 05:43 AM
Benja's Avatar
Dynojet figures are basically ~15% higher than the average Mainline/DD dyno we usually use here in Australia.
So thats ~317wkw, which for 28psi and those breathing mods is bang on.
I bang out 270-320wkw setups regularly on 98 octane here, so its no different really.
The last Red I did on 98 went 285wkw on 22psi on my dyno, which is ~440whp Dynojet.
Old Jul 8, 2015, 01:56 PM
bawse.c's Avatar
Tuners over here dont even achieve these results on hub dyno over here so...
Old Jul 8, 2015, 02:13 PM
Evo9_Dubai's Avatar
I have tried Haltech, and switched back to oem ecu. I found it much easier to tune and had better failsafe. Also, the oem has flexfuel capacity now, can't beat that
Old Jul 9, 2015, 04:20 PM
Dragracer187's Avatar
Put it on a Mainline and then do the comparison. You cannot compare VD to DD or Mainline.
Old Jul 13, 2015, 08:57 PM
nzevo8's Avatar
iv found VD is 16% higher reading then our New Zealand Dynopack hub dynos. This was just in comparison to a Dynopack at the local reputable workshop. In New Zealand we have 3 petrol companies that offer 98Ron octane. I do know that 1 of the 3 petrol companies 98ron when compared to U.S equal to 94 octane.
In the last 2 months Iv also change my set up slightly and had a recent touch up tune which produced a little bit more power.
Boosted Tuning
Mar 31, 2016 08:35 AM
Boosted Tuning
Jun 29, 2014 09:19 AM
Boosted Tuning
Jul 6, 2013 07:03 AM
Boosted Tuning
Mar 4, 2012 06:45 PM
Boosted Tuning
May 10, 2011 09:14 AM
Quick Reply: BOOSTED TUNING Custom Remote Tune - JDM EVO 8/FP Red on 98 RON
