Pulling Evo 8 motor out from top DIY needed...
Old Apr 30, 2011, 12:15 PM
wizzo 8's Avatar
I pulled mine from the top. Took me about 10hrs and wasnt as bad as pulling the trans by itself. I think If I had to do a clutch in the future I would just pull the motor w/trans from the top again to replace it.
Old Aug 20, 2016, 07:36 PM
Srt4...'s Avatar
Does anybody have pictures or description of lifting points for using chains with the cherry picker
Old Aug 20, 2016, 08:20 PM
barneyb's Avatar
Yeah, I'm curious too. The transmission is heavy so where is the center of gravity when you lift.
Old Aug 21, 2016, 02:12 AM
roni4g63's Avatar
So am i, i usually use a thick strap and loop it around the block and trans. Lol
Old Apr 3, 2017, 10:51 PM
silverevo05's Avatar
Any pics?
Old Apr 3, 2017, 11:57 PM
kaj
kaj's Avatar
Remove trans and axles.
tie up the t case
pull radiator
Lift engine.
boom
Old Apr 4, 2017, 12:00 AM
kaj
kaj's Avatar
P.S. the head has lifting points attached. Attach chain there. Use a load leveler to made it even easier.
I had mine out in a couple hours, but I'm getting really used to it.
Old Apr 5, 2017, 12:40 PM
V.8MR's Avatar
I left trans attached. But I removed hot side and cold side from the head, radiator, and unbolted/mated the TC and moved it towards passenger side.
Load leveler is key because you have to lower the trans side down below the frame rail.
Old Jul 23, 2017, 07:50 AM
wizzo 8's Avatar
Load leveler at full tilt. Engine with trans.
hokiruu (Nov 20, 2019)
FiReBReTHa
Lancer How Tos / Installations
Jul 9, 2020 06:03 PM
Phoenix*
19
Oct 2, 2017 05:05 PM
Tougefreak
May 25, 2017 06:20 PM
FiReBReTHa
Jul 18, 2016 08:07 PM
FiReBReTHa
Jul 18, 2016 08:05 PM
Quick Reply: Pulling Evo 8 motor out from top DIY needed...
