evo 8 clutch problem??
Old May 25, 2011, 08:34 PM
aldoevo's Avatar
i just got my tranny rebioult and a new act clutch 6 pad spring disk with a used act heavy duty pressure plate and when ifirst take of in 1st gear there is alot of vibration coming from tranny .wen i get the car rolling it stops vibrating is this a normal thing with these clutches? also if im going over a speed bump and shift back into first wen car is rolling it dosent vibrate.
Old May 25, 2011, 08:41 PM
BLK_EvIL's Avatar
sounds like clutch chatter 6pucks do this more then others it should quiet up in a few hundred miles
Old May 25, 2011, 08:42 PM
aldoevo's Avatar
yea it just vibrates really bad anoying in traffic shakes the hole car lol
Old May 25, 2011, 08:45 PM
BLK_EvIL's Avatar
ya try to dump it at a little higher rpm insted of slipping it slowly helps on my 6puck
Old May 25, 2011, 08:46 PM
aldoevo's Avatar
did that i dump it at about 2k rpm slowely for it not to vibrate car
Old May 25, 2011, 08:49 PM
BLK_EvIL's Avatar
How many miles on it and did you get the flywheel resurfaced? Also if you dont you should get SS full clutch lines and remove the restricter pill in the slave cylinder give you move precise control and feel of the clutch engagement .
Old May 25, 2011, 09:04 PM
aldoevo's Avatar
so far only have 200 miles on clutch and tranny and flyywheel was resurfaced
Old May 25, 2011, 09:14 PM
MrDgaf's Avatar
Give it time it should smooth out.
Old Jun 24, 2013, 11:04 PM
Dbz00's Avatar
Need help I just install a new act 6 puck clutch in my evo 8 but it feel like the clutch is slipping.
evoforstevo
Jul 21, 2017 05:07 PM
Welcome2GoodBur
Mar 13, 2017 04:45 PM
MREVO9NOOB
Sep 27, 2016 06:15 AM
flippymcbean
Jun 18, 2016 11:14 AM
bvdawg13
For Sale - Cars For Sale
30
Aug 15, 2007 06:22 PM
Quick Reply: evo 8 clutch problem??
