Concrete method to determine if bov leaks under driving wot condition?
Old Jul 14, 2013, 11:38 AM
211Ratsbud's Avatar
What is a concrete way to check this? I don't like static tests.
One way I thought is to run a rubber stopper with a single hole, a barbed fitting feeding a boost gauge. If during a wot pull you see the gauge read pressure it's leaking. It would be normal to see small changes at tip in I suppose.
Thoughts? Probably gonna be a day or two before I try this ( gotta get to the winemaker for the stopper)
Old Jul 14, 2013, 12:31 PM
MyronGainz's Avatar
I don't know what you've tried, but a regular boost leak test will tell you 100% if the BOV is leaking or not. It should not be venting air back into the intake tube under your specified pressure
You can literally hear it and feel it leaking. Pretty definite answer there if you ask me
Old Jul 14, 2013, 01:43 PM
rich3389's Avatar
Boost leak test, way to overthink the situation LOL.
Old Jul 14, 2013, 02:43 PM
211Ratsbud's Avatar
I just didn't feel that represents peak load situation .. But if that's the consensus ill go with it
Old Jul 14, 2013, 06:00 PM
browningderek's Avatar
Boost leak testing puts pressure on the piston as well as the diaphragm. So thats a good test. Another test is to remove your bc, make a pull. remove the bov and block the hole. Make another pull. If boost goes up its leaking. Or if you find that you have turned the BC way up and it should be boosting more. Block off the bov again and boost should go up. On an Evox I have just clamped the bov hose and boost hit 33psi. Lol
Old Jul 14, 2013, 07:03 PM
TommiM's Avatar
boost leak testing you will pressurize the intake pipe that the bov is on just like the turbo would.
Old Jul 14, 2013, 08:02 PM
211Ratsbud's Avatar
That's a pretty dynamic happening, what I felt you could t replicate with an air compressor.
But I can certainly agree with the static test.
Well, ill have to make a blt for my 84mm cover regardless lol
Old Jul 15, 2013, 05:07 AM
sparky's Avatar
Am curious, incidentally, what DV/BOV is on there anyhowz, Ratster?
Old Jul 15, 2013, 06:38 AM
heel2toe's Avatar
To add a personal experience, in my case I try to BLT my car to 30# as I spike 28# on the street. The car will hold pressure fine until about 27-29# where I hear a pssshhh sound. Sure enough my IX uncrushed DV starts leaking right then. Moral of the story a simple BLT(I keep thinking about food) is a simple way to check the function of your DV/BOV
Darkn3s
Sep 11, 2013 01:53 PM
Name User
Apr 23, 2013 08:49 PM
packrat
Cobb AccessPORT
Jun 27, 2012 02:31 PM
evo8mrr
15
May 28, 2010 07:33 AM
Evo_Jr
Jan 31, 2007 10:34 PM
Quick Reply: Concrete method to determine if bov leaks under driving wot condition?
