ACD fluid leaking
ACD fluid leaking
Well I am having ACD fluid leak from right in front of the driver side tire. It drains the whole reservoir in about a week or two. Any idea where the leak could be coming from? The fluid is everywhere in that area so I cant really pinpoint it. Thanks.
I would bleed it just to make sure there is no air in the system. You need two people. One underneath the car working the acd bleeder screw on the transfer case, and one to turn the ignition to the on position (dont start the car). When the ignition is turned on, you need to open the bleeder screw because the pump will cycle fluid. Once fluid comes out, you need to close the bleeder screw. Repeat this process until no air comes out.
Btw, you need to open the bleeder screw a decent amount to let the fluid come out.
evo.matt
Nov 20, 2014 01:05 PM
volkevo9
Dec 5, 2011 03:40 PM
