Egr cel please help me
Old Mar 1, 2013, 08:10 AM
Tommytooth's Avatar
I got the egr insufficient flow code and I replaced the egr valve, selonid, the hoses and it still hasn't gone away. I was looking at the intake manifold and it looks very dirty where the egr valve mounts would cleaning it fix the problem?
Old Mar 1, 2013, 08:20 AM
analogEvo's Avatar
Did you connect the egr hoses correctly underneath the intake manifold? Mine has popped off a few times. Did you clear the code after the fix?
Old Mar 1, 2013, 08:25 AM
OfaceGrimmins's Avatar
If you use the search feature on these forums, you will find that this is a very common problem. Behind the egr valve are ports that exhaust gases flow through. Due to the nature of an internal combustion engine, there is a large amount of particulate carbon floating around in the egr system. Remove the valve, and perform a coat-hanger abortion with some brake cleaner and then use compressed air to blow it out. Re-install your valve and clear the codes - poof. Done. If it comes back AGAIN, you didnt abort hard enough. Stick the coat hanger in that ***** until she screams. That is all.
Old Mar 1, 2013, 08:31 AM
SilverShadow03's Avatar
LoL!!! Awesome response!
Old Mar 1, 2013, 08:45 AM
Tekniq's Avatar
Originally Posted by silvershadow03
lol!!! Awesome response!
+1. Lol
fostytou
338
Nov 10, 2023 11:55 AM
LakerRaider
May 17, 2017 04:20 PM
EvoooB
Oct 26, 2015 11:42 AM
BarryC
Sep 10, 2009 12:22 PM
EvoDan2004
Jul 23, 2007 06:01 AM
Quick Reply: Egr cel please help me
