Turbo Swap... Manifold studs!
Hey Everyone,
So I am going to be swapping out my stock turbo and manifold for a ported manifold and FP black in the next week or so. I am curious some tricks to get the exhaust manifold off? My bolts are almost completely missing and I feel like they are all going to break... I would rather not have to take my car in to a shop and have the holes drilled out. I bought a stud removal set and have had great success getting broken studs out in the past. Has anyone had any luck with this? Or any tips to help me get everything apart easier? I bought ARP SS Manifold studs to replace them with.
Thank You,
Thank You,
DO NOT use an impact gun, especially if your bolts are in terrible condition. Use a swivel joint and a 3-5" extension with a breaker bar and carefully turn counter-clockwise.
IF the bolt is seized, what I did was carefully drilled/dremmel both sides of the bolt flat without making contact with the studs and use a visegrip to yank it out.
To take out the studs, use the double sided bolt method. there's plenty of youtube videos showing how you can do that.
Also, another tip when taking out the 4 studs that are mated to the turbo to the exhaust manifold. You dont want to take them out one by one, you are better off taking one off about 1/3rd, and then working your way around the other studs. This way, you wont end up stripping the last bolt
I used this guy right here:
I had about less then half an inch of the stud sticking out... This thing clamped so hard on that stud and pulled it right out...
I used a lot of PB Blaster and a torch. They all came right out.
If i remember correctly i had to make the one stud a little wider, so i just went at it with a welder until it was thick enough for the stud remover to grab it.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
As for tips and tricks, a lot of people have already said to soak the nuts. After you let them soak, get a small wire brush and clean off any exposed threads. This will aid in the removal of the nuts and you'll be less prone to snapping a stud.
I just went through this headache about a month ago. One of my studs snapped and I had to drill it out. It was easy, but still a pain in the butt.
yeas
This story below made me a believer.
I had a stainless exhaust with steel V-band fittings.
I could not get the v band clamp off of the fitting for one of the joints, it was rust welded on there.
So I removed the entire exhaust from the car, PB blaster, WD40, hammer, giant screw driver..... not coming off.
Found out about this mixture, spray it on.... 30 mins later, the joint literally fell apart. Now its what I use 95% of the time
I tried removing everything when we did my cam install and we ended up just removing the head with the exhaust because nothing would move so I would like to get the studs out this time and replace with the stainless steel. Hopefully my stud puller will work if the studs break. 1 broken stud is enough for me.
drivejumpfly
Dec 22, 2015 05:57 AM
ryukinevo
Feb 8, 2014 09:42 PM
