New info on SSL with aftermarket Headunit
Mods might wanna sticky this, not sure if I'm in the right place so please move if you need to.
Got most of my info from this thread:
https://www.evolutionm.net/forums/ev...-unit-ssl.html
Heres a copy of the most relevant post in the thread posted by outsider:
Some of those links are 4 and 5 years old. Not sure if those companies are still around. Did some checking and found that Amazon.com sells the Metra 70-7003 which is the combo and includes both harnesses that you would need to install a aftermarket headunit in your SSL evo, while keeping the use of your sub and amp.
Heres the link:
http://www.amazon.com/gp/product/B00...ef=oss_product
Joe
Ok, so let me try to go ahead and cut everything short and sweet, as I found lots of pages on this but some confusion.
If you have an SSL equipped EVO, you will need two different harnesses to be able to use your aftermarket HU (headunit) and retain use of the stock amp & sub.
1) To use the stock amp & sub, you will need the "MITAH" adapter (Peripheral MIT) which has 4 RCA's which plug into your new HU, and the a factory rounded connector which goes into your harness. It also has a blue wire which you must join with your factory blue/white wire. You may also use the same adapter from another company called Soundgate "MITSRCVR" which does the same thing.
You can buy the "MITAH" from this link:
http://store.yahoo.com/logjam/piehrcmit.html
http://www.discountcarstereo.com/detail.aspx?ID=434
You can buy the "MITSRCVR" from here:
http://store.yahoo.com/logjam/sounmitsrcvr.html
https://www.soundgate.com//index.php...ategoryid=187&
2) You also need a harness for your power plug. This is the "Metra" adapter.
This can be found here:
http://www.discountcarstereo.com/detail.aspx?ID=433
Now, I found two places that sell both as a combo:
http://www.autotoys.com/x/catalog/MI...SS_p_1379.html
http://www.audioallies.com/getitem.a...70-7003&Sys=FR
That is what I have found through my own searches and those of others here on EVOM. I haven't bought any of these myself YET, as I'm in the process of gather info to buy what I need. If any of this is incorrect, please feel free to correct me!
Heres the link:
Joe
alexc
Jul 9, 2016 10:19 AM
Flip
Nov 5, 2010 06:55 PM
tetsuo12333
Mar 8, 2010 02:33 PM
