OK i need HELP!! PLZ!!
OK guys i was replaceing my rotors i was done with the fronts easy as pie, i used the radiator screws to pop the off, thanks to an evo member suggestion! now the problem... i cant get the back rotors off!! i used the screw to try to pop the rotors of but it looks like theres somekind of spring or something holding the rear rotors in place! i used the screw but i cant seem to pop it they just bend and bend but cant seem to come off, help guys!! thanks in advance!!
Did you have the parking brake engaged? The parking brake is a drum brake inside the hats of the rear rotors. You have to release the parking brake to get the rear rotors off. Also, it should be a little harder to get them off than the fronts.
-Paul
-Paul
escodotcarter
17
Sep 21, 2010 06:16 PM
xchanhxlex
19
Jun 27, 2006 12:32 PM
