OT - Valve lifter
4B11's don't have lifters. They are bucket on spring, and you need to know the gap between the valve stem and the cam, because the buckets also serve as shims for setting lash.
There are 47 different part numbers of buckets.
Well, yes, this is exactly what I need - e-shop for the buckets. I know the gaps on each valve and would need to order appropriate buckets. Valve lifter was wrong translation from my side :-)
When you order your buckets, make sure you subtract the lash spec from the thickness you order. I'm sure you thought of that since you already have the gap dimension, but I just thought I'd throw that out there.
MAPerformance has a decent OEM mitsubishi parts connection.
There is also http://www.mitsubishiparts.net/
Martin
itsmrrizz2you
14
Jul 21, 2014 08:19 PM
ilikeppie
26
May 31, 2012 01:52 PM
bigturboevo80
Aug 27, 2010 07:08 PM
