do i hear knocking in idle?
Old Nov 9, 2011, 06:46 PM
o0oz's Avatar
hey guys.. im not exactly sure what it is that i am hearing coming from my motor but sounds like knock... just a bunch of tick tick tick tick tick sounds as the motor idles.. any ideas if its a normal thing or not? i usually hear it as its loudest after iv driven for a good while.
here are some logs i pulled off the car if it helps, thanks.
ign advance (9/12)
knock retard (0.0)
learned knock retard (100%)
intake cam adv (10/11)
maf (g/s) (3)
boost pressure (-9.4/-8.8)
load boost/fuel (29/30)
load timing (19/20)
load limp mode (19/20)
im a currently running aem intake, hks bov, greddy se exhaust and ecu reflash to cobb ap aem 91 stage1.. this ticking noise has been going on like this before i bought the cobb ap.
any help would be greatful, thanks again.
Old Nov 10, 2011, 12:23 AM
xhomm02's Avatar
I guess there is something loosen in the engine making this ticking noise while the pistons are moving under (almost) no load on idle.
Old Nov 10, 2011, 12:30 AM
02-Lancer-Es's Avatar
Sounds like lifter tick which is very normal to hear on all 4B11's , my wifes 4B11 Lancer Gts is very noisy but has always been like that since it was brand new .
Old Nov 11, 2011, 10:44 PM
Widoww's Avatar
or its his noisy sst tranny like the rest of us put in drive, R, it pretty much goes away you only notice it idling as all the clutches are freely moving
Old Dec 2, 2011, 12:29 PM
wallace989's Avatar
mine nocks too at idle i think it is normal but im no expert
Old Dec 14, 2011, 07:41 AM
oftheheavens's Avatar
it is your injectors and is normal.
Old Dec 14, 2011, 12:38 PM
Kracka's Avatar
This.
Old Dec 14, 2011, 01:22 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
the clutches clatter at idle
Old Dec 15, 2011, 07:23 AM
shawnburch's Avatar
Mine does it too. The first few times I heard it, I almost freaked out. I've gotten use to it by now and just dont worry about it.
nadevo
Aug 4, 2016 07:46 AM
EVOEvolved
Jul 12, 2016 08:17 PM
kyracer1989
Dec 31, 2012 12:43 PM
skforty
Aug 25, 2011 02:00 PM
smithrcing17
29
Sep 23, 2010 12:46 PM
Quick Reply: do i hear knocking in idle?
