clutch master cylinder
I did the install myself. It's kind of a pain and time consuming, but totally doable.
Read over this a few times and decide for yourself if it's something you want to attempt..
http://magnusmotorsports.com/wp-cont..._mastercyl.pdf
It doesn't matter that the install instructions are for a Magnus brand part. AMS and MAP install will be the same.
it wasnt bad.. it was pretty time consuming and the hardest part for me was grinding the 2 holes because of the tight space..btw when your removing brake fluid reservoir make sure you dont loose the oring because i lost mine and i had vacuum leak for a week..you might need to bleed your brakes too
MisUnderStood
48
Oct 3, 2017 07:57 AM
flyingscot
Jan 15, 2013 09:41 PM
Rasputin
Lancer Tranny/Drivetrain Tech
31
Jul 16, 2012 07:04 PM
joyce1bro
Jul 20, 2008 02:06 PM
