Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Dimmer wire pick-up for gauges?
Old Mar 19, 2010, 07:24 AM
HybridKOOP's Avatar
Tephra, what does this wire do? Is it a 12v on/off with headlights? Or is it a variable step down in voltage that changes with dimmer levels?
Lou
Old Mar 19, 2010, 05:42 PM
tephra's Avatar
should just be on/off
Old May 11, 2010, 07:28 AM
EvoM Community Team
fostytou's Avatar
As a semi-intelligent update .... the blank also has a plug in it with a green/white illumination wire, so you don't have to cut / tap into a wire that actually does something!
Old Mar 30, 2014, 01:28 PM
Youngsyr's Avatar
A hell of a thread bump, but I'm looking for an easy illumination wire to tap and have a couple of queries I was hoping you guys could help with.
Which blank is Fostytou talking about?:
And is pin 10 on C311 the 10th pin from the right on the top row?
Old May 4, 2014, 07:39 PM
lunchfist's Avatar
I was in the same boat... i just installed a triple gauge pillar in my 04 Lancer ES... figured i'd hook up the illumination to the dimmer switch.. There was a black, black-yellow, and a green-white wire, and i tapped into the black-yellow... when i dim my dash lights it brightens my pillar gauges lol.
soooooooooo.... not quite sure where to go from here... research time i guess.
i'm kind of wondering if i can't just swap the positive and negative leads on my pillar gauges?
Old May 5, 2014, 02:58 PM
ikt
ikt's Avatar
ugh no just tap it off the stereo harness behind the deck. Power, ground, 12v ACC and dimmer are all right there.
Old Apr 30, 2016, 05:31 AM
BWDuke's Avatar
Still works on a 2015 GSR
Originally Posted by evoluXrichie
This:
I did this this morning and the green wire with the white stripe from the headlight leveler is what I tapped into and it works great. Lights off gauge is bright, lights on gauge is dim. Perfect thanks I've been looking for this for a while now.
Old May 5, 2016, 07:38 AM
BackWoodsBoost's Avatar
I was wondering if anyone has ever used a 5-way toggle switch or a volume/tone knob from a guitar to regulate the voltage, i feel like finding a place to mount it wouldn't be that challenging, I feel like that would be a better alternative than having to dig through the wiring harness searching for the dimmer wire
trinydex
141
May 18, 2018 09:34 AM
silverevo05
Feb 22, 2018 12:22 PM
Dawood Dy
Apr 14, 2016 05:32 PM
Gh3ttoRoM3o
21
Mar 15, 2016 07:08 PM
usmcmarine915
Feb 17, 2016 04:38 AM
Quick Reply: Dimmer wire pick-up for gauges?
