Community Tephra Tweaking
Old Apr 16, 2011, 09:47 AM
  #961
Mitsu.kid.02's Avatar
Originally Posted by RoadSpike
Yes but you would need something for the map sensor to work off of remember its speed density not alpha N which is more of a ITB setup.
What SD needs is a vacuum line behind the ITB plate probably all 4 of them tied into one line for a good average.
If the car was to be tuned Alpha-N style the whole system would need to be reworked.
WTH is Alpha-N??
Old Apr 17, 2011, 12:09 AM
  #962
RoadSpike's Avatar
Originally Posted by Mitsu.kid.02
WTH is Alpha-N??
Its a race car system basically its all guessing for the motor it equates load directly tied to throttle percentage and delivers fuel based on that. So since it requires only a throttle input its super responsive and fast but not accurate.
It can't be used on a boosted system without a correction for pressure.
Old Apr 19, 2011, 04:12 AM
  #963
Interesting!
Old May 1, 2011, 11:32 AM
  #964
MurphDurph's Avatar
does anyone have a legend or key as to what each item box means/does in ecuflash?
Old May 1, 2011, 09:59 PM
  #965
RoadSpike's Avatar
What "box" do you mean
Perhaps you should goto the ecuflash forum and start reading the stickies plenty of "how to's" in that place.
Old May 1, 2011, 11:06 PM
  #966
MurphDurph's Avatar
the items in the "current rommetdata" column...basically like a brief explanation of each bullet in "x" category. i did look through the stickies and didnt find anything...another member asked the same question, but was never answered. i quoted and posted the same question in the thread as well. i know the basics, but just wanted to have an insight on what all the other stuff does
Old May 2, 2011, 01:17 AM
  #967
RoadSpike's Avatar
I'll take "looked through" as really skimmed through the stickies for names exactly matching your problem?
Look for merlins guide to tuning evos Google it if you have to. There is not a better more complete explanation for everything in tuning in existence i can assure you.
Old May 2, 2011, 11:41 AM
  #968
03lances's Avatar
+1 I downloaded that guide long ago and I was always referring to it.
Old May 2, 2011, 11:51 AM
  #969
MurphDurph's Avatar
awesome, thanks RS
Old Oct 29, 2014, 11:09 AM
  #970
fknlowpsi's Avatar
what does the P0830 Clutch Pedal Circuit do? and if it is set to 0 it should be disabled right now correct or by default? if i set it to 1 should that let me start the car without pressing in the clutch or with a remote start???
Old Nov 21, 2014, 06:17 AM
  #971
02modlanceroz's Avatar
If you just unplug the switch on the floor behind the clutch, you can start the car without it pressed in
Old Nov 21, 2014, 10:47 AM
  #972
CrAnSwIcK's Avatar
make sure it's in neutral!!! lol
Old Nov 21, 2014, 02:45 PM
  #973
I thought that was a given. Lol I have a turbo timer so mine is always in neutral. I keep thinking about getting a remote start for mine, but I have to adjust my primer enrich tables a bit and mess with the ac values so I'm not pegging my rpms way up.
Emilio Pons
Nov 8, 2017 12:17 AM
Hiram6g74
Aug 1, 2017 07:12 AM
DormantBeast
13
Jul 9, 2017 07:38 AM
Evo_Goodness
Aug 30, 2016 04:00 AM
T_Jochum24
Apr 1, 2009 12:41 PM
Quick Reply: Community Tephra Tweaking
