rrm piggyback AT help
i bought a piggyback off a member on EvoM (TAJ) and he included the install instructions but I'm having some trouble..in the instructions it says to connect the piggyback vacuum line but this particular piggyback doesn't have a vacuum line opening..he says he had it installed on his lancer..anyone else have a piggyback like this on their 02?
The vaccum line is for version 1 of the piggy back (older). Version 2 does not have a vaccum line. I'm guessing you have version 2 because there is not vaccum line. Make sure you take your time when you hook it up. I believe you use the wires with the black dashes on them (if you have dashes).
Jake
Jake
***Please edit this post to be in compliance with the new FS rules or else it will be deleted, thanks***
https://www.evolutionm.net/forums/sa...uncements.html
here's the color diagram for how the wires are connected for the RA
https://www.evolutionm.net/forums/04...tructions.html
i'm not sure if the color wires are the same but it gives you an idea of how it is supposed to be connected
Ryan Evans
Lancer Engine Management / Tuning Forums
Jun 29, 2016 11:11 AM
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 7, 2010 07:18 PM
