Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
2002 Lancer OZ clutch problems
Old Mar 13, 2009, 04:47 PM
lancerguy0208's Avatar
When I start my car, I push the clutch pedal in and the car starts fine. But when I try to put it in gear the shifter doesn't move and there is a faint noise like the gears are moving but unable to engage. I can't tell if its anything from a minor problem like leaking fluid or something to do with the slave cylinder, or something up to where I would need a whole new clutch. Somebody please help me.
Old Mar 13, 2009, 05:12 PM
depsy's Avatar
had a similar problem...ended up being my gears, hope you just need a new clutch and not that
Old Mar 13, 2009, 05:47 PM
03_Lancer_ES's Avatar
Is it like trying to shift without clutching? That kind of noise? Could be that your clutch isn't engaging...dunno, shot in the dark
Old Mar 14, 2009, 02:02 AM
Orville's Avatar
car just did the same thing tonight... gonna find out on the am and let everyone know with pics...
Old Mar 16, 2009, 11:31 AM
blaze_125's Avatar
How's the clutch pedal feeling? Is it hard to push? Does it feel like there is nothing there?
If you feel something wrong in the clutch pedal it could be fluid related; running low, major air bubbles, slave failing and so forth.
Your clutch feeds off the brake cylinder fluid so make sure you brake fluid is full. If it's not, fill it up with a fresh bottle. Not a bottle that's been sitting open on the shelf for weeks, months or even years. Fill it up with a freshly opened bottle.
Are there any "new" sounds coming from the engine bay? Rumbles, grindings, clicking, or whatever..
Old Mar 26, 2009, 02:05 PM
It turned out to be the slave. I knew somethin was leaking cause it was sucking air somewhere but I couldn't find out where. Then I realized the slave on my car is internal. haha Thats why I couldn't find the leak. Anyway, I'm gettin it fixed by a friend who is a mechanic. Should be good to go in a couple days.
Old Jun 26, 2011, 06:30 PM
both76's Avatar
I have the same promblem, my car starts but it won't go into any of the gears. The clutch feels like its not even there and it was making some weird noises in the engine. How do I find out whats wrong?
Old Jun 27, 2011, 10:33 AM
blaze_125's Avatar
Take out the trans, inspect the slave and the clutch.
Change whatever needs to be changed.
Old Jan 12, 2017, 03:02 PM
Veronica38's Avatar
I push my clutch in an my car sounds fine. When i release the clutch i here a very loud noise, sounds like something is not engaging?? Help!!
Old Jan 14, 2017, 12:56 AM
CrAnSwIcK's Avatar
can you shift gears easily with the car stopped and engine running? what kind of noise is it?
roni4g63
May 21, 2020 07:43 PM
Sandroc
Jul 12, 2017 12:42 PM
2006GSR
Sep 10, 2016 06:10 AM
Bananayellowevo
Apr 25, 2016 09:54 AM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
Quick Reply: 2002 Lancer OZ clutch problems
