Have a weird clutch drag issue. Exedy triple/2.4L
Hey guys.
I have a weird clutch drag issue.
2.4L exedy triple. Master adjusted all the way out. Got like 2 more threads left on the rod.
While clutch pedal is pressed in all the way. Trans in first gear. Flat surface. At 7k car don't move. At 7500 starts to creep forward and at 8-8500 it basically launches itself. Clutch has about 1k miles on it. Possible that I warped a floater in the clutch?
Thanks
Thanks
is that true?
It's going to become a measurement game.
There is a degree of deflection that Exedy has written somewhere in their website about your pressure plate (CM06H). It tells us the exact distance that the plate needs to be pulled (or pushed depending on your setup) in order to disengage the clutch disks completely.
Have someone push your clutch pedal to the floor while you measure the distance that the slave cylinder moves the clutch fork.
If it more or less matches what Exedy has on their pressure plate spec sheet, then we know that the clutch could be warped somewhere.
Truth is, i'm not even sure if it's worth fixing because you wouldn't be reving that high in a 2.4 anyway. Hope you find the problem soon.
-pal215
-pal215
-pal215
-pal215
I think i will ditch the 2.4 and go with a 2.1L. But at first i will measure out the discs if they arent warped. I figured if they where arped. It would drag at 5 6 k rpm. not at 7500 and over.
evotris
14
Sep 28, 2012 06:59 AM
SmurfZilla
45
Feb 26, 2012 01:37 PM
konstantinosIX
13
Sep 25, 2011 12:51 PM
