A/C Compressor issues
Hello I have a 2002 lancer that the A/C compressor will not engage. I don't believe the compressor is bad. I have checked all the fuses and relays for the system and nothing is burned out. The single wire that goes to the A/C compressor when hooked to a test light gives no sign of having power. I am at a loss have checked everything I can think of. I tired charging the A/C and the compressor worked for a little bit then just stopped. Is there a common system short? Thanks for any feed back in advance.
if the system ran with a mild charge then went out---you have a system ac Freon charge issue...if the Freon is too low it wont come on. If its clicking in and out, off and on with a small charge you need more for it to engage and stay on.. go vacuum the system and recharge and it will work.
