Lancer blowing hot air
Old Jun 18, 2014, 08:23 AM
Thahomeboyb's Avatar
So Ofcourse my ac wants to start blowing hot air in the summer . How do I fix it ? Is it as simple as needing more coolant in my car ?
Old Jun 18, 2014, 02:15 PM
RT78's Avatar
If the a/c system is just low on refrigerant, then yes, recharging the system will work. However if you have a leak, it won't last long. I've been told by longtime tech's that the refrigerant can gradually seep out if not used for long periods of time, if that's the case you have to have the air evacuated from the system with a machine designed to do just that. It pumps in refrigerant in one port, and draws the air out of the other, most shops have them.
Old Jun 18, 2014, 02:54 PM
By recharging you mean by putting more refrigerant in ?
Old Jun 19, 2014, 03:14 AM
RT78's Avatar
Yep, the stuff is a bit pricey though, and if you do it you'd need a gauge to measure the pressure of the system(some of the cans come with them) compared to the outside air temp. The one thing you don't want to do is over pressurize the system, that will definitely give you problems.
frankiecutz
Oct 12, 2016 08:21 PM
Spythere
Jul 5, 2016 03:09 AM
soderdna
Jul 19, 2015 09:29 AM
Photool
Lancer Troubleshooting
26
Jul 6, 2015 10:00 PM
warpedminds
Jul 22, 2005 11:32 AM
Quick Reply: Lancer blowing hot air
