How to: adjust valve lash
Old Jan 8, 2013 | 06:56 PM
  #106
deathsythe99's Avatar
when do have to do this? or what is the reason to do this? im doing the head rebuild on my car and i dont want ticking noise's.
Old Jan 10, 2013 | 04:30 PM
  #107
CrAnSwIcK's Avatar
check the lash as soon as its back together...
Old Jan 11, 2013 | 08:48 PM
  #108
how do i know if i need to adjust it?
Old Jan 12, 2013 | 08:04 AM
  #109
lanzerralliart's Avatar
EvoM Super Moderator
Use the feeler gauge to see if the intake is at 0.20 and the exhaust at 0.30 , if it's not then adjust them. There will always be a ticking noise though (fuel injectors)
Old Jan 12, 2013 | 04:31 PM
  #110
CrAnSwIcK's Avatar
that's in mm?
Old Jan 13, 2013 | 06:47 PM
  #111
yea but what i dont want is it sounding like a tractor.
Old Jan 13, 2013 | 08:02 PM
  #112
Thomar's Avatar
Haha, it wont.... just follow the service manuals specifications on setting the valves, then warm the engine, then set them again one final time to the normal specs and you're good to go.
Old Jan 14, 2013 | 01:04 PM
  #113
CrAnSwIcK's Avatar
it's not too bad...
make sure the transmission is in neutral, you WILL need to crank the motor manually to set TDC for certain cylinders depending on which set of valves you are measuring the lash...
Old Jan 14, 2013 | 05:20 PM
  #114
i need to study on this . sounds difficult and this is the first car ive ever done anything too. its only my second car.
Old Jan 14, 2013 | 05:34 PM
  #115
AdamRA's Avatar
Take your time and in order to take your time you will need to take the car for a long drive in order for it to stay warm, winter is not the ideal time for this job.
I've done it 3 or 4 times now... enjoy the burnt hands.
Old Jan 14, 2013 | 06:20 PM
  #116
CrAnSwIcK's Avatar
lol, wear gloves...leather if possible
Old Jan 14, 2013 | 06:48 PM
  #117
AdamRA's Avatar
Yes wear welding gloves while adjusting the valves.
Old Jan 15, 2013 | 05:23 AM
  #118
RalliartN's Avatar
Is this worth getting to do our valves - would it make things easier?
http://www.amazon.com/10mm-Honda-Val.../dp/B004QK2APS
Old Jan 15, 2013 | 01:57 PM
  #119
CrAnSwIcK's Avatar
that's a handy tool you found there, Nick i remember ours are like philips pattern, but more like a "dual common" so that just might work
Old Jan 21, 2013 | 05:33 AM
  #120
RalliartN's Avatar
fyi, Partsource sells it for $20! I checked on Saturday, they only had a 12 mm so they're ordering in a 10mm for me this week. It's not the "made in USA" (Schley) I would prefer but it should never break anyway, the stress on this tool is minimal.
