How to: adjust valve lash
Old Jan 21, 2013 | 02:49 PM
  #121
AdamRA's Avatar
I bought one of these tools thinking it would be the end all of valve tools...
I got much more accuracy using a screwdriver and an open end 10mm
Old Jan 21, 2013 | 04:59 PM
  #122
CrAnSwIcK's Avatar
well that's a load load of **** in my corn flakes
i'll used RalliartN's and see what i think before i buy one
Old Jan 22, 2013 | 12:32 AM
  #123
nodnarb's Avatar
So was reading older posts and someone said they would be posting up a video? Has anyone come across a video on how to adjust our cars?0
Old Jan 22, 2013 | 05:18 AM
  #124
RalliartN's Avatar
Crans, hasn't one of the 4g69 engine builders on the eclipse site posted a video?
Old Jan 22, 2013 | 05:27 AM
  #125
RalliartN's Avatar
Interesting. Ah, worth a shot.
AdamRA, did you use the bent-end feeler gauges or straight ones? I only have straights.
Cranswick, if you want to try it this winter let me know, we can use warm shop if it's too snowy out. Else wait till spring when I check mine? Hey, what am I saying, aren't you stateside until the spring?
Old Jan 22, 2013 | 08:50 AM
  #126
AdamRA's Avatar
I used straight ones the first time, bought angled for the next time. The intake side is the worst.... even with angled.
Old Jan 22, 2013 | 03:34 PM
  #127
CrAnSwIcK's Avatar
jhun maybe?
I'm in Charleston, SC till march
i used the "hockey stick" gauges when i did mine too, wasn't much help as you said
Old Apr 30, 2013 | 09:39 AM
  #128
bakuro117's Avatar
Has anyone found a video on how to do the valve lash? Im planning to do it this weekend while I have my valve cover off. So I was wanting to see as much of it as I can before I try this for the first time.
Old Sep 29, 2013 | 10:59 PM
  #129
Dnh143's Avatar
I've been reading this whole thread cause im planning a DIY valve adjustment, but i have the RRM Pulley and did not put a mark or notch on it. So now how do i find out if my timing mark is good, because i know i have to crank the pulley til it hits timing mark? Any help.
Old Sep 30, 2013 | 04:37 AM
  #130
CrAnSwIcK's Avatar
rrm pulley and serpentine belt have nothing to do with timing...
Old Sep 30, 2013 | 07:09 AM
  #131
Dnh143's Avatar
So when i do my valve lash i dont have to worry about lining up the crank pulley? Just adjust to specs? Kinda confused i thought i had to turn the engine or something?
Old Sep 30, 2013 | 07:48 AM
  #132
RalliartN's Avatar
uh oh
Old Sep 30, 2013 | 07:59 AM
  #133
Dnh143's Avatar
uh oh
Lol what do u mean? I havent done it yet. So was it important to mark the rrm pulley prior to diy valve lash?cause i didnt.
Old Sep 30, 2013 | 08:21 AM
  #134
CrAnSwIcK's Avatar
the crank sprocket behind the pulley sets crank timing...as the crank pulley is installed after and outside of the lower timing cover...there may be timing marks on the rrm pulley, but i wouldn't even go by that. you would be wise to use the timing mark on the cam gear to find top dead center for number 1 piston...always turn the motor clockwise, and pull out the spark plugs for two reasons; 1. hand cranking is easier cause there's no compression, and 2. you can visually verify TDC.
Old Oct 7, 2013 | 07:33 PM
  #135
Dnh143's Avatar
I will be attempting this procedure tomorrow.
Just this part was my first initial worry: "Turn it CLOCKWISE by hand until the timing mark on the pulley lines up with the "T" on the timing cover. (Hope you guys with Joe's pulley put some kind of mark on yours before installing it, like I did)".
But since u said to go by the cam gear i will do that instead. Thanks again, i will keep it updated on how things go.
