need to know this asap
Old Sep 6, 2006 | 02:00 PM
wide open boy's Avatar
can some on help me realy quickly is they a way to put racing seat on with out geting the proper instale kit cuz i can get a set of seats tonite but i need to know if i can fit em tonite is there a way to use my rails on those seats
Old Sep 6, 2006 | 03:32 PM
morpheus256's Avatar
probably not, in my experience all after market seats allways came with their own set of rails. someone else who has installed seats however might have a better idea.
Old Sep 6, 2006 | 05:40 PM
Joyrider's Avatar
you can maybe do some custom work on the OEm brackets like washers and so, but really time consuming !
Old Sep 7, 2006 | 11:07 AM
ya but what about the srs air bags and stuff are they just not going to work anymore
and is there avalabel brakets for my seats
Old Sep 7, 2006 | 11:14 AM
Punkskalar's Avatar
SRS Will set a DTC code if you remove the stock seats... No way to get rid of that code either... May upset the rest of the SRS components in an accident as well... As for brackets to make seats fit, i've always had to modify some stock ones...
Old Sep 7, 2006 | 11:24 AM
has any one done this on a ralliart or am i a firts
and this isnt my only probleme i to them of and teste fitted my new ones now my srs light wont turn off
Old Sep 7, 2006 | 12:00 PM
Punkskalar's Avatar
Its not ever going to go off either unless you disconnect all your SRS components from the car and remove the dash light... Not worth it in my opinion...
If you removed them with the car battery still connected, you defintely set off a code in the SRS unit that cannot be reset until you restore the system completely and have the SRS unit cleared of any codes you have already set... Disconnecting the battery can temporarily reset the light IF you have the stock seat in place...
Old Sep 7, 2006 | 08:35 PM
bruce988jl's Avatar
well you can wire up a resistor i believe.. i've seen it done, dunno how it works. but you basically cross it to make the computer think its still there. And instead when the airbags try to deploy it just discharges the resistor or something like that...
google it or something maybe it'll come up
good luck
-Lee
krillin
31
Jan 24, 2016 08:55 AM
sonicrx
Nov 4, 2015 08:10 PM
Howulikemyevo
Apr 15, 2015 05:25 AM
kanyonkid
Jan 12, 2009 12:40 PM
RENN-ART
36
Dec 20, 2003 12:21 AM
