Removing the Clutch Master Cylinder
Old Dec 27, 2006, 09:35 AM
MyRoN's Avatar
Okay guys, so i tackled this job last night. To my surprise it was not hard at all. Took me about 30 mins (including taking pics) So here goes ..hope it helps some one out.
cheers
Myron
1-drain the fluid in the resavoir
2-discconect the hose
3-loosen the banjo bolt
4-carefully remove it with both copper screws
5-locate the 2 bolts that hold the Master cylinder form inside the clutch. Loosen both of them
6-disconnect attachment from clutch pedal
7 remove master cylinder
8-U GOOD TO GO(now i had to flip mine around in order to get it out of that small place.
GOOD LUCK
Attached Thumbnails Removing the Clutch Master Cylinder-pc260001.jpg   Removing the Clutch Master Cylinder-pc260004.jpg   Removing the Clutch Master Cylinder-pc260005.jpg   Removing the Clutch Master Cylinder-pc260006.jpg   Removing the Clutch Master Cylinder-pc260007.jpg
Old Dec 27, 2006, 09:41 AM
MyRoN's Avatar
PM if you need anything or have any questions.
Attached Thumbnails Removing the Clutch Master Cylinder-pc260008.jpg   Removing the Clutch Master Cylinder-pc260011.jpg   Removing the Clutch Master Cylinder-pc260012.jpg   Removing the Clutch Master Cylinder-pc260013.jpg
duderr_666
58
Aug 18, 2015 10:44 AM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
Apr 24, 2012 06:45 AM
MyRoN
17
May 21, 2008 05:20 AM
MyRoN
Feb 11, 2008 09:33 PM
MyRoN
Aug 8, 2006 06:14 PM
Quick Reply: Removing the Clutch Master Cylinder
