Cleaning up the speedometer cover
Old May 23, 2007 | 09:36 AM
samj601's Avatar
the plastic cover for the speedometer is starting to get on my my nerves. its covered with alot of light scratches and its very noticeable since its so sunny out now. is there anything out there that can clean it up and get rid of the scratches?
Old May 23, 2007 | 09:44 AM
Thegreydevil219's Avatar
yeah try Mothers Plastic polish, its a very fine grit polish, and it takes away small scratches and abrasions works wonders, i swear by it
Old May 23, 2007 | 10:26 AM
StreetGasm Maus's Avatar
a friend of mine had the same problem and he used meguiars polish and polisched it
now it looks perfect
Old May 23, 2007 | 10:58 AM
DangerousDan's Avatar
take it out(cluster), remove plastic cover, replace(cluster). voila! no more scratches!
Old May 23, 2007 | 11:21 AM
samj601's Avatar
lol i dont wanna replace the cluster i just want the plastic cover to look new again. i just got this meguiars plastic cleaner and polish so maybe that might work.
question tho. how do u take the plastic cover apart from the cluster? i've taken out all the screws but i cant figure out how to remove tha actual cover form the from the sppedometer.
Old May 23, 2007 | 11:38 AM
I will look when I get home if someone else hasn't already. it should just be some plastic tabs. there is a diy on the cluster lights in the lancer diy forum that will tell you if you can't wait for me to get home
Old May 23, 2007 | 12:11 PM
otter's Avatar
EvoM Administrator
You have to pull the entire cluster. Once you do that, you'll see a bunch of plastic tabs that you can release to get the clear cover off. But at that point, you might as well leave the cover on, since the cluster is out of the car.
Old May 23, 2007 | 05:27 PM
see, beat me to the punch. I knew someone would
BlackEvoV
Lancer Troubleshooting
Dec 8, 2015 06:26 AM
Sir_Lancer_Lots
Nov 22, 2015 06:43 PM
Brad676
Aug 13, 2014 10:10 PM
silverevo05
Jun 19, 2011 12:34 PM
►EvolutionX◄
Apr 23, 2009 04:58 PM
