Engine Swap Now in Progress - Photos!
Old Dec 15, 2006 | 02:21 PM
  #241
Myszkewicz's Avatar
Originally Posted by Diavlo
the idle now seems pretty stable but its at 1500rpm.
As the ECU learns, it will lower the idle speed.
Old Dec 15, 2006 | 02:22 PM
  #242
Diavlo's Avatar
here is the video, id recomend saving this peice of pure unscripted reaction!
Please forgive my really soft english accent.
http://www.coasterforce.com/dan/car_start.wmv
Old Dec 15, 2006 | 02:28 PM
  #243
Myszkewicz's Avatar
Awesome vid.
IT LIVES!
It doesn't sound that loud to me.
Old Dec 15, 2006 | 02:36 PM
  #244
NorCal Lancer's Avatar
hahaha congrats man! oh man, you acted like you created frankenstein in that video, hahahaha
Old Dec 15, 2006 | 02:39 PM
  #245
Diavlo's Avatar
Guess im used to the 1.6's tiny exhaust! I guess we didnt really know if this was possible. Much was left down to whether the wiring was the same over the crossovers between new 2.4 wiring and old 1.6 - seems it was mostly all the same.
Heres another vid of it running!
http://www.coasterforce.com/dan/car_running.wmv
Old Dec 15, 2006 | 02:44 PM
  #246
Myszkewicz's Avatar
Sounds very much like I'd expect it to with the exhaust you've put on it. The stock exhaust is pretty loud, especially if you're used to a tiny engine that exhales through a drinking straw.
Old Dec 15, 2006 | 02:57 PM
  #247
Diavlo's Avatar
Haha! We threw 4 codes today from reving the engine a bit.
P0446 - Evap Incorrect flow
P0441 - Evap control circuit
P0183 - temp sensor fault (its not connected yet)
And after the ECM learning process we got:
P0000 - No Self-Diagnostic Failures Present
Old Dec 15, 2006 | 03:26 PM
  #248
otter's Avatar
EvoM Administrator
Congrats on the start!
If your car is idling at 1500 rpm, it may be in limp mode. When my car was put in limp mode earlier this week, it was idling at 1500, and I couldn't rev it past 3000.
EDIT: nevermind, video looked like you were passing 3000.
Old Dec 15, 2006 | 03:39 PM
  #249
captain150's Avatar
Nice! Doesn't sound bad/loud to me. Since it threw some codes, it's probably not idling/running as good as it will. Awesome that it started the first "try". With a job as huge as this, it's surprising and impressive you didn't have to iron out any mistakes or oversights.
As for the ticking, I know the 4G69 makes a slight ticking normally, but if it's too loud, make sure you got some oil coming up to the head (should be as easy as peeking into the oil cap opening in the valve cover after running it for a minute.)
Old Dec 15, 2006 | 05:39 PM
  #250
klown78's Avatar
Amazing, Congrats man!!
Old Dec 15, 2006 | 05:58 PM
  #251
cokeandrum01's Avatar
That is soo crazy!!!!
Congrats from Southern Cali...
Old Dec 15, 2006 | 06:05 PM
  #252
vito1's Avatar
Good luck with the block.!! Lord knows i could never see my car like that..lol
Old Dec 15, 2006 | 06:08 PM
  #253
WoRkZ's Avatar
"IT LIVES! IT LIVES!
Uhhhh... uh, ho... smoke... "
LMAO!!!
BTW: I think it sounds okay...just a bit louder than mine, so that's about right. I got pulled only once because of the stock sound... maybe you'll get pulled only once or twice a year for yours.
[EDIT: It's still weird to see the throttle cable going to the other side of the engine bay... What are you going to do with it... it wouldn't be a good thing to let it sit on the engine. I see it's also a bit long because of the shorter distance... ]
Old Dec 15, 2006 | 08:07 PM
  #254
sP33Dy's Avatar
LMAO @ commentry and "it Lives' .. PURE GOLD
I cant imagine the excitement you would of felt as it kicked over - it's been a long time coming!
Congrats from Country Australia .... and i look forward to some pics of it out on an road!
Old Dec 15, 2006 | 09:02 PM
  #255
amax's Avatar
Congrats! Get that fuel pressure sensor hooked up though - Probably has something to do with rough high idle. Same goes for fuel temp sensor. Keep up the good work.
