Engine Swap Now in Progress - Photos!
Old Nov 7, 2006 | 02:33 PM
  #91
Jasidus's Avatar
Originally Posted by Diavlo
I'm driving around in a Mitsubishi 5 door Colt Ralliart Version-R - my mums car. 1.5 Turbo Mivec. It's ok, but its got NO power before 3500rpm at all, you can floor it and it wont accelerate at all. At 3500rpm you get a little pull, not much - 0-60 in 8s. It looks gash too. I am however going to be buying a 1.5 3 door colt diesel soon as my runabout, because they get 70mpg and 0-60 in 9s and 161ft lbs of Torque.
I'm sorry, but what do you mean by gash?
Old Nov 7, 2006 | 02:40 PM
  #92
Diavlo's Avatar
lol, british slang for it looks awful.
The front I like - the back I dont. The 3 door one however is nice front and back.
Anyhow, tomorrow I will be installing a complex oil cooler system that will do the following:
- Relocate the oil filter to a more convenient location
- Pass oil through a thermostat valve, if the oil is less than 170F it sends 95% of it back to the engine, if it is over that temp, it sends it through the cooler.
- Take a reading of the oil temp before the cooler, and display result on a gauge in the cabin.
- Pass engine oil through a front mount oil cooler which has a temp-activated fan.
- After the oil cooler the oil passes through a module which turns on the fan if the oil temp is over 170F after its passed through the cooler.
- Oil passes through a second temp sensor which displays cooled oil temp on a gauge in the cabin.
I'm such a geek - and I'll love being able to see exactly what my engine oil temp is then seeing how much the cooler cools it. Pics tomorrow.
Also, I looked at the shop manual for an Evo 7-9 today and I noticed the fuel pump I had to return was an Evo one. New one is being delivered this week sometime.
Old Nov 7, 2006 | 09:22 PM
  #93
Myszkewicz's Avatar
Sounds like a nice oil cooler setup. Or maybe I'm showing my geek roots.
Your total oil capacity will be somewhere near 6 quarts, then.
Old Nov 8, 2006 | 02:19 PM
  #94
Diavlo's Avatar
Today we fitted the oil cooler, and installed the oil hose up to the thermostat valve - the next connections would be the remote oil filter then the engine, so we'll leave that till the engine is in.
I mounted the HID Ballast units out of the way, and We installed the wire from the oil temp gauge sensors through to the cabin.
I'm now looking for a RHD pillar with two spaces for 50mm Diamter gauges!
Old Nov 8, 2006 | 02:46 PM
  #95
DangerousDan's Avatar
That is FAN-tastic. What makes you think the oil filter is hard to get to? I think the 4g69 is by far the easiest engine I have had to change oil on. Excellent progress man, keep the pics coming, I'm getting more and more excited for you
Old Nov 8, 2006 | 03:02 PM
  #96
Myszkewicz's Avatar
Location, and vertical mounting. I have to slide my head and arm under the car to get my hand up there to take off the filter, and you have to unscrew it quickly to keep oil from running down the sides of the filter and all the way up your arm.
My old car had the filter mounted horizontally down under where the battery is in the RA. Very easy to get to, and no oil all over my hand/arm.
Old Nov 8, 2006 | 03:08 PM
  #97
Diavlo's Avatar
The main reason im going for filter relocation, is because using a sandwich adapter for the oil cooler puts the oil filter closer to the ground.
Jobs left to do now:
Replace fuel pump
Install brass shifter bushings
Install Sway Bar Poly Bushings
Install underhood brass shifter bushings
Remove return fuel line
Attach transaxle to engine
Then begins the process of installing the new engine.
Old Nov 8, 2006 | 05:05 PM
  #98
That makes sense then. Any word on the transaxle shipment?
Old Nov 8, 2006 | 05:11 PM
  #99
Diavlo's Avatar
It was on Fedex 3-5 day international shipping, being posted from Portland, OR. It's brand new, fully assembled - ready to use. Should be here by early next week.
It looks like we'll be done by end of next week.
Old Nov 8, 2006 | 05:14 PM
  #100
pao's Avatar
pao
Oregon??? ALRIGHT!!!
Old Nov 8, 2006 | 05:15 PM
  #101
otter's Avatar
EvoM Administrator
Downside with horizontal mounts, though, is you can't prime them.
Old Nov 13, 2006 | 12:30 PM
  #102
Diavlo's Avatar
Today we finished wiring up the oil cooler fan, then I removed the A-pillar ready for the twin 52mm gauge pod one that will arrive on wednesday.
My fedex transaxle shipping now reads:
Nov 13, 2006 7:57 PM
At dest sort facility
STANSTED GB
So it is now in my country and due on the 15th still.
That means wednesday I will have photos of the new engine in the car, if it does get delivered then.
I just recieve the brass shifter base and underhood bushings too, so they will go in on weds.
Either way, everythings look good.
Old Nov 14, 2006 | 03:09 AM
  #103
reTro's Avatar
Does every part you order have to go overseas? My gawd it must cost a fortune to mod any car for you Brits!
Old Nov 14, 2006 | 03:40 AM
  #104
Diavlo's Avatar
All the parts are only available in north america - same as the car!
Anyhow look what arrived today! Engine in tomorrow guys!
Transaxle fully assembled ready to use!
Front sway bushes:
Old Nov 14, 2006 | 03:48 AM
  #105
Myszkewicz's Avatar
Do yourself a favor and gut that restrictor or replace it with a new clutch line.
