04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Custom Turbo for Automatic
Old Jun 16, 2007 | 04:12 PM
samj601's Avatar
i was wondering if i picked up an used rrm turbo kit from a manual ra, what parts do i need to switch to get it to work on an auto? just the fuell management right? everything else is pretty much the same i suppose?
Old Jun 16, 2007 | 05:57 PM
stEVOx's Avatar
should be same, maybe tight fit tho
i also have an auto and trying to turbo it, but dont know what fuel management to use:
greddy emange (blue or ultimate)
rrm piggy (split second?)
rpw haltech e6x
any help appreciated
Old Jun 16, 2007 | 06:20 PM
akinakin's Avatar
Just the Fuel/Timing MAP.......most importantly, the TIMING MAP.
The...er....EVERY automatic uses MORE timing (advance) than a standard transmision model, ask ANY engine builder or someone who knows a thing or 2...so, the STANDARD MAP will NOT pull enough timing out under boost, causing detonation.....I have witnessed this first hand on a friend's car....BOOM !
Not that being retarded is cool....lol, but I would rater over-retard than run the risk of detonation. Low end torque benefits as well, just leaving a little loss on the top end HP.....not a big deal. Retard to put the power where it counts......in a driveable range, like off idle.
Be careful and get your tune done on a Dyno that can LOAD.....not a DynoJet. More guys have leaned out after a DynoJet tune and detonated than any other dyno because of the way it CAN NOT simulate a REAL world driving condition to give you a proper tune.
Take care and all will be well.
Allan
Old Jun 27, 2007 | 07:34 AM
Pikachu's Avatar
Originally Posted by Muck
I know RRM has a turbo ready for the automatic and is anxiously waiting for somebody to step up and get the first one done, but since i live in Canada that just isnt realistic. So my question is, what would need to be done to build a custom turbo setup for my Automatic. Parts,setup,insight... anything is appreciated.
Thanks, Muck
If you do go ahead with this, dont forget to strengthen your gearbox. You could strengthen it with Level 10 or Import Performance Transmission.
Old Jun 27, 2007 | 03:42 PM
ralliartjapracr's Avatar
i have a turbo manifold and an ftc1 for sale for your custom kit
Old Jun 27, 2007 | 04:52 PM
akinakin's Avatar
Off Topic, but...
What made you decide to drop your project ? Buying a pre-built kit ? or another car ?
aggieEVO
Dec 10, 2012 01:40 PM
Muck
Dec 4, 2006 09:05 PM
Muck
17
Sep 29, 2006 09:40 AM
Muck
Sep 21, 2006 08:50 PM
lanca-lot
Australian Forum
Feb 16, 2005 06:58 PM
