04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
still bogging???TURBO HELP
Old Dec 13, 2007 | 05:55 AM
DangerousDan's Avatar
could still be his stock injectors. one of them not functioning properly at WOT would cause one cylinder to go lean and that's gonna cause issues. I would imagine the CEL should be lit because of the turbo anyway, have you tried getting the codes pulled to see if there is an unusual one stored? the light doesn't need to be on for the code to be stored, iirc.
Old Dec 13, 2007 | 08:20 PM
edovio's Avatar
thats good too know, i dont have a code reader yet but ill be getting one just for trouble like this. i didnt know that it could be throwin cels w/o the light actually coming on. other than that once i put the cel eliminator that came with the kit on the light went away and never came back.
its a great product even though it would be really easy to make.
im very sure its human error with my lean condition as rrms products are very good , the welding is the only flaw i see. but im a welder/boilermaker so i see alot of high quality welds versus header welds that dont need to be ut's or pmi'd
anyways,,nuff ramblin
Old Dec 14, 2007 | 04:27 AM
not throwing CEL's without the light, just that it may retain the codes after the light goes out. also, you can see what codes are getting ready to come up, which could help you diagnose something intermittent as you are describing. some sensors require error conditions to persist for xx amount of time, and if they don't the light doesn't come on. during this xx amount of time they are stored as pending codes.
so the eliminator worked for you huh? that's good, some people have had no luck with it.
RRM's products are good, but unless they tuned your car it's still just a base tune. also, are you able to log from your wideband sensor?
Old Dec 14, 2007 | 04:41 AM
.50 Cal Cow's Avatar
have you had your car tuned since you put all these parts on there? tuning is your friend when you are throwing a lot of mods in.
Old Dec 14, 2007 | 10:00 PM
edovio's Avatar
naw no tune as of yet i was told i didnt need one, although i will be regardless as i have a few mods that would affect the origional mapping of the piggy . i look forward to the tuned beast it will be
Old Dec 15, 2007 | 06:38 AM
everyone is being told that lately. that's like saying don't buy a piggyback because the stock ecu can compensate. it's a stupid comment.
Old Dec 15, 2007 | 01:06 PM
edovio's Avatar
thats what i figured im sure a tune in january will make me kick back in the seat,,,ahha,,i cant wait
Old Dec 15, 2007 | 02:59 PM
AdamRA's Avatar
I've never understood why people will throw so much money into the car and not tune it !!!!!! My car won't be leaving the shop in Jan. without a tune...
Old Dec 15, 2007 | 03:22 PM
MITVRX's Avatar
I have to totally agree with you. Everyone should know by now I hunt down those RA who have alot of mods without a tune!
Tunes do wonders, get it tuned, do yourself justice as well as your car.
Old Dec 17, 2007 | 08:54 PM
edovio's Avatar
fuel pump
i think i might have found my problem, the fuel pump was creating problems so i removed it for inspection numerous times, and when reinstalling it would not start, stock one was replaced and started no problem,
Old Dec 18, 2007 | 06:46 AM
chowetime's Avatar
It is proably too late to be posting as it looks like you may of solved part of the problem I was also getting a slight bogging this was due to runing lean nothing serious and was easily fixed.
I think part of the problem that we have with the cars is that they have the fly by wire T.B and a non return fuel line hence this is why we need to have bigger injectors fuel rail and possibly fuel pump - the throttle works almost too well it will give us instant air into the car but the fuel system can not keep up with the demands which causes the bogging down on WOT the reason why the car does not produce this effect colder days is because of the air sensor which is also saying that the TPS needs to be slightly more open and pump slightly more fuel like it does when you first start the car up... an automatic choke?
Old Dec 18, 2007 | 09:20 AM
I agree, having the FPR in the tank, while probably cost effective for mitsu, doesn't allow for much to work with in the way of reaction time for your fuel.
4G63_EVO
Jun 8, 2017 10:02 PM
Mikami
Aug 28, 2015 03:11 PM
evolution520
Oct 11, 2013 11:25 AM
GearDownSon
14
Apr 12, 2010 09:21 PM
Rallilanc
63
Mar 14, 2008 04:46 AM
