04-06 Ralliart Engine/Drivetrain (no forced induction)
Took the RA to the track
Old Jan 10, 2005 | 08:52 PM
MitsuSkot's Avatar
Originally Posted by engineerboy
If you want to find 2nd, you need to get at least a firmer front motor mount and then redo the entire shifter system: go to a short shifter, replace shifter base bushings and both underhood bushings. You'll be shifting crisper and faster all day in every gear!
absolutely. i replaced all the shifter components, and what a difference.. I love it.
Old Jan 11, 2005 | 05:52 AM
Freddie1111's Avatar
I checked the article...it wasn't a 60' time, but rather a 0-30 mph time (2.4 sec).
Old Jan 11, 2005 | 07:03 AM
miltown RA's Avatar
anyone know what a auto ra does in the 1/4 ???
Old Jan 11, 2005 | 08:20 AM
shiroboi's Avatar
Impressive time, 15.3
Old Jan 11, 2005 | 08:35 AM
coolmivec's Avatar
yea people , 15.3 is very good and the 2 gear stuff at high rpm is very true , damn 2 jejejejejee
Old Jan 11, 2005 | 01:30 PM
miltown RA's Avatar
Old Jan 11, 2005 | 03:31 PM
DallasN2O's Avatar
Ok, after some testing today I figured out that if the wheels are spinning in first gear and you try to shift to second you can forget it. You have to launch this car around 2500-3000 rpm and dont sidestep the pedal. Unless you are on slicks/DRs and you launch higher than that or sidestep it, you wont ever get it to second gear. I pulled a 2.3 60' twice but couldnt engage second gear either time. Only after I launched at lower RPM without spinning did I finally get it to shift but then had a 2.4.
I agree with the motor mount statement. This motor is so damn torquey it likes to shift when the tires are spinning and that seems to throw off the shifting just enough to screw you up. I have no problems with the throw distance or any of that, but I gaurantee the motor mount stiffening would fix the problem and would result in a 2.2 or better on stock tires. If you could pull a 2.0 in this car on stock trim I know you would be looking at 14.7-14.8. Would be extremely hard to get a 60 like that on our tires though I'm afraid. Mine has Potenzas and they do ok with 20 psi and a nasty burnout.. but you guys with the BFG's or whatever the ****ty ones are, it'll never happen.
Old Jan 11, 2005 | 03:52 PM
mxstripes71's Avatar
That's something I would like to know as well but can't find anywhere...I would only assume it would be around low 16's or so...
Old Jan 12, 2005 | 10:27 AM
reimundo's Avatar
auto 16-flat i think.
Old Jan 12, 2005 | 12:43 PM
Widebody Lancer's Avatar
you shouldnt be doing a burnout with street tires just a chirp to get dirt off since street tries are designed to be run cold at there stickiest not litten on frie froma burnout. but ya tires would help the 60 ft time the most, i dont have a problem getting it into 2nd at all i have a problem sometimes from 2nd into 1st at 7000 rpm hehe but got that down too for this race season.
Old Jan 12, 2005 | 01:41 PM
Alchemist's Avatar
From 2 to 1 at 7K?! dude, you're mental and are gonna eff your engine... unless there's some crazy metric to SAE conversion your applying to your RPM figures....
Old Jan 12, 2005 | 02:32 PM
Rallilanc's Avatar
engineerboy how much did your ported intake manifold cost?
Old Jan 12, 2005 | 02:39 PM
pgmike's Avatar
^he ported it himself.
Old Jan 12, 2005 | 05:05 PM
DallasN2O's Avatar
Doesnt matter what kind of tires you have, if you heat them up they will get softer and stickier. Try launching your car at 4000 rpm in first gear and shifting to second right before redline. If your tires are spinning you will never do it.
I hope that 2nd to 1st at 7000 statement was a typo.
Old Jan 12, 2005 | 05:15 PM
pgmike's Avatar
^lol you dont even know what you are talking about. street tires are different from drag slick lol. you heat up slicks, not street tires.
