04-06 Ralliart Engine/Drivetrain (no forced induction)
Performance Part Review
Old Feb 26, 2013 | 07:02 PM
  #226
truthdweller's Avatar
Veteran: Navy
Originally Posted by SSP-Ralliart
i used to race a 8sec camaro back in the day. Ran a powerglide two speed. Ran 9s on a 3speed THM350 automatic.
Now you're revealing your age? Roadrunners, SS's, Cuda's, Stang's...ah, the 70's...
Old Feb 27, 2013 | 12:53 PM
  #227
CrAnSwIcK's Avatar
muscle cars are different...and a car like that probably would not do well in autocross/road course...and yeah, that's old people talk... Sounds like she was a beast though
Old Feb 27, 2013 | 01:17 PM
  #228
bakuro117's Avatar
Drag racing autos can be mean when they are built right!
Makes me wish the auto was more tune-able. Hopefully it will be soon.
Old Mar 8, 2013 | 06:06 PM
  #229
turboart's Avatar
Sry was takin to the wrong place again
Old Mar 8, 2013 | 09:02 PM
  #230
Veteran: Navy
Do you have hackish's flash which makes the shifting noticeably crisper/sharper after he changes the throttle angle? When he finds an automatic car he'll spend some time with it and see how aggressive he thinks it should be, he told me. I currently have it uploaded, along with the 7200 rev limiter, which you can only take to that limit by shifting manually, otherwise, the engine will shift at it's predetermined limit of ~6300 rpm if left in "D"rive, and, therefore, traction is now an issue when launching for the first time since buying the car in '04! You NEED to get this if you don't have it already!
Old Mar 11, 2013 | 06:27 AM
  #231
xmaster19's Avatar
The baddest Supras out there all convert to GM auto trannies. Their puny manual trans cannot take the abuse (here, read 1000+ whp) the Turbo series trans can. Also alot cheaper to run.
Old Mar 11, 2013 | 09:05 AM
  #232
bakuro117's Avatar
I dont have it. But I have been wanting it for a while. But Ive been debating on putting off working on my car any more than maintenance now. Ive really got a bad itch to start saving for an evo... lol
Id love to keep working on my RA cause Im going to keep it even if I do get an Evo. But the more I work on the RA the less $$ I can put toward an evo...
Old Feb 23, 2014 | 01:36 PM
  #233
lbwilliams44's Avatar
I have seen a few positive reviews for the RPW stage 1 cam, has anybody tried the stage 2 or their cam gear?
Old Mar 16, 2014 | 10:31 AM
  #234
Veteran: Navy
Forge FMDV008 Diverter Valve
Review: The weight of this device gave me the first impression that I was getting something for my money. It's smooth, high gloss, painted surface with the engraved "Forge" logo, as well a it's obvious technical design and construction, makes it stand out among it's competitors. The ability to maintenance it, or change out the springs by removing its hex key bolts is a plus. It's performance is as the Audi TT 1.8 recirculation valve that I had previously, but the sound is less turbulent, the response is crisper, and what tickled me the most was it's suttle, high pitched report that it gives off upon deceleration in my automatic transmission! What does all this mean as far as performance? I don't really know, but just knowing that I have a quality piece of serviceable engineering under the hood that I paid a nominal fee for, from an evom member, made it totally worth it.
Old Mar 16, 2014 | 11:09 AM
  #235
Veteran: Navy
Forge UNOS Manual Boost Controller (MBC):
A MBC was recommended by hackish, et al, soon after I completed the turbo build on my car back in July, 2013. It wasn't until last week though that I finally followed through. I finally can stop dragging out the jack, stands, and other tools required, to crawl under my car to make the adjustments to my WG actuator!
I'm finding out as well, that this device, although still an estimation game, is a much more accurate method than the aforementioned procedure! Construction wise, Forge comes through again with a bullet proof, simple, serviceable construction, complete with two mounting brackets and hardware, and a soft and firm spring to accommodate boost pressures.
Smike
144
Jul 6, 2021 06:56 PM
BLKRalliArt04
111
Dec 3, 2018 03:53 PM
boomn29
94
Aug 29, 2012 01:04 PM
BLKRalliArt04
74
Feb 28, 2012 06:33 AM
Speedlimit
Sep 8, 2011 01:29 PM
