04-06 Ralliart Engine/Drivetrain (no forced induction)
Piggyback Gas Update
Old Dec 7, 2005 | 09:17 PM
ROCK's Avatar
Under servere load you can bet RA pulls timing when using lower octane fuel. So.... Maybe it is not in your head!
ROAD/RACE
Old Dec 8, 2005 | 03:19 AM
otter's Avatar
EvoM Administrator
Originally Posted by RALLIART2U
Thanks for the reply BLK I dont know but my head is feeling a diference in power between premium and regular gas (93and 87). Escuse me I'm newbie and I'm finding a lot of knowledge on this forum . My question is why if there is no gain between both types of gasoline then should be one type only . Im ready to learn again my friend!
Search around the forums, or google, and read about octane. Octane is what determines the flashpoint of gasoline. High compression engines, and high performance engines (such as forced induction engines) need a fuel with a higher flashpoint. This allows them to run with advanced timing, thus able to compress the a/f mix more before igniting it with the spark plug. With a lower octane fuel, you'd run the risk of detonation, which is when the a/f mix ignites before the spark plug tells it to.
The reason there are so many different types of gas (87, 89, 91, 93, 100, 116) is due to both cost and performance demand. 87 octane is the least expensive to produce, and is the best octane rating for most cars, as most cars come with a compression level in the same range. Some cars would probably run just fine on something like 85 octane, but not enough of them to make it worth producing it. Mathematically, someone figured out that 87 octane is the lowest that it's financially responsible to produce. Everything above that is made for engines that actually have a need for it.
Old Dec 8, 2005 | 08:31 PM
RALLIART2U's Avatar
So we can conclude that since high octane permits the a/f mix to be more compressed due to the higher flashpoint and ignited when the spark plug tells ,the explosion per cilinder will be more stronger producing more power ,
right? Please understand that if i dont understand this or cannot express my self clearly is because english its not my main language
Old Dec 9, 2005 | 01:25 AM
candycain's Avatar
Registered User
you are correct!!!!!! on a side note, i think the RA could use higher compression. i bet if we had 11:1 like an rsx-s our cars would make even more power with the piggy!
Old Dec 9, 2005 | 03:43 AM
RALLIART2U's Avatar
Tnx candycain ,what number its our compresion?
Old Dec 9, 2005 | 09:20 AM
Eclipse2Lancer's Avatar
9.5 to 1.
Welcome to the boards and read this thread: https://www.evolutionm.net/forums/sh...d.php?t=108090
Lots of good stuff there to read.
Old Dec 9, 2005 | 09:40 AM
BLKRalliArt04's Avatar
I actually know of at least 3 other people who use 87 octane with their piggyback. They all know that this isnt a mod that heavily changes anything, (for lack of a better word). None of us have any issues. Heck, I know of a guy with an evo and he uses 87. Wow we're a buncha penny pinchers!
Old Dec 9, 2005 | 09:59 AM
blaze_125's Avatar
Sorry... my post did not really belong here... so I asked the question in the right thread.
https://www.evolutionm.net/forums/sh....php?p=2615858
Old Dec 9, 2005 | 07:39 PM
twisty1251's Avatar
wow an evo using 87
Old Dec 10, 2005 | 02:35 AM
sweet_bucket22's Avatar
Yeah it can be done... however timing gets pulled and power drops considerably. Only way to use 87 without this happening is by adding an injections system. (alky or meth)
ricanevo
Southeast Region
32
Oct 1, 2008 10:53 AM
blk-majik
Aug 14, 2007 06:10 AM
MitsuRalliArt
May 4, 2004 09:17 AM
Teetoe24
Feb 24, 2004 09:43 PM
