04-06 Ralliart Engine/Drivetrain (no forced induction)
Service Engine Soon!!!
Old Dec 22, 2006 | 08:03 AM
cokeandrum01's Avatar
I was on the freeway going to work and this morning and the Service Engine Soon light came on. I checked all the fluids, belt, gas cap, and found nothing. The car isnt driving funny or anything. I am going to check for codes when I get a chance to later. I was looking for a plug in for the scanner and couldnt find one. Can someone tell me where it is at? I checked the dash near drivers-side lower left where most cars have them and found a little compartment but it was empty.
My mods are Injen CAI and RRM Pulley just incase anybody asks. I checked the intake for any sort of leaks with no luck.
Old Dec 22, 2006 | 08:18 AM
otter's Avatar
EvoM Administrator
Look underneath the dash, just to the right of the steering wheel. You'll see two ports, one is the OBDII port (the one you want) and the other is the MUTS port (Mitsu's proprietary port)
Old Dec 22, 2006 | 08:44 AM
Ok, thanks otter for the help.
Old Dec 22, 2006 | 02:08 PM
Code P0304...Misfire in cylinder 4.
I cleared the code and test drove it and everything seems to be running fine. Should I have anything to be worried about? It is still under warranty but it takes about 4-5 days to get in at my dealership.
Old Dec 24, 2006 | 11:38 PM
hellview's Avatar
sory newb question. but how do u check the codes
Old Dec 25, 2006 | 03:46 PM
otter's Avatar
EvoM Administrator
You need a OBDII code reader. Most autoparts stores have them behind the counter, and they'll check a code for you, and they also sell them. You can also buy a cable and check them with a laptop.
I wouldn't worry about the misfire unless it happens again.
Old Dec 25, 2006 | 07:39 PM
Truffle Shuffle's Avatar
If my light is on because of the 2nd 02 sensor (Custom exhaust) is it possible to just clear that code? and have the light go off forver?
Old Dec 25, 2006 | 08:18 PM
KreepaEvoX's Avatar
You dont really get the code from exhaust, its mostly by eliminating the cat.
Old Dec 25, 2006 | 09:13 PM
rally-on's Avatar
what is the cable called for the laptop otter and do u need any softwere for the laptop
i think it would be good to have
thanks
Old Dec 25, 2006 | 11:23 PM
CF-Ninja's Avatar
thanks
http://www.amazon.com/s/ref=nb_ss_au...0&Go.y=0&Go=Go
Amazon has several hand held as well as USB kits starting from about $50
Old Dec 26, 2006 | 05:18 AM
Ryan_VRX06's Avatar
Is that light an american thing?
I've never got a service soon light - or do you mean the CEL?
Old Dec 26, 2006 | 08:27 AM
MyRoN's Avatar
If you go to your auto parts store, like checkers, autozone, they do the testing for free. and give you a nice print out of what the problem is. I got that message as well,
and i was told to run sea foam thru the system. I still get that message especially when its cold outside, and i start my baby up. Its over the warrenty so i think i'm just going to replace that F/I. The light comes on and off. Its weird..but yeah my car does mis fire a little bit. especially at idle.
Old Dec 26, 2006 | 09:35 AM
otter's Avatar
EvoM Administrator
SES = CEL
The cable for laptops can be found here. This cable is specific to Mitsubishi, so if someone ever figures out how to flash our ECU, you can do it with this cable. You do need software, and have a couple options. First is EVOscan, which costs about $25, available here. Another option is some software put out by AktiveMatrix.com, MalibuJack's project. He has both his own logger there, as well as a generic OBDII logger, for free.
CF-Ninja
Jan 20, 2014 12:19 PM
impact blue
Feb 6, 2013 06:32 AM
Svendiesel
Nov 15, 2009 11:07 PM
wewii
Jun 14, 2008 07:16 AM
Ironman
Nov 9, 2004 04:31 PM
