04-06 Ralliart Engine/Drivetrain (no forced induction)
All Motor hp???
Old Nov 13, 2007 | 01:34 PM
fkdrcrs's Avatar
All Motor hp???
since rrm might not make their turbo kit by the time im ready to purchase it, i was thinking of going all motor.
my plan would be P&P head, P&P IM, header/dp, cam, and n/a piggy w/ a good tune. i already have an sri and AB exhaust and id be happy with 200hp.
could i achieve that hp? if not, what other parts could i look into to get it there?
thanks
Old Nov 13, 2007 | 01:37 PM
fkdrcrs's Avatar
oh........ and i also have an udp.
Old Nov 13, 2007 | 02:15 PM
PR_Mivec's Avatar
buy high comp pistons and good rods for it...
Old Nov 13, 2007 | 05:59 PM
Blitz19's Avatar
think on fuel...pump,rail,injectors and regulator
Old Nov 14, 2007 | 05:37 AM
fkdrcrs's Avatar
thanks guys, although im not sure where to look for pistons and rods for the RA.
Old Nov 14, 2007 | 01:13 PM
Ralliart_on_LSD's Avatar
If u get the motor worked, throw some NAWS on there (n2o)
Old Nov 14, 2007 | 05:35 PM
DangerousDan's Avatar
+1, why not get the juices flowing
I have a spare camshaft in my head at home, you could take it off my hands and have it reground like I had my turbo cam done
of course if you buy the head from a junkyard it will likely come with a camshaft...
Old Nov 14, 2007 | 08:32 PM
illusion's Avatar
where can we get fuel mods for our cars since I havent seen anything on RRM you know like a FPR, Fuel Rail lil bit bigger injectors... Also can you fit 3000gt N/A injectors in a RA I know it would be dumb considering they are V6 injectors, but just curious...
GearDownSon's Avatar
Vin deisel approves of NAWZ
Old Nov 15, 2007 | 05:12 AM
fkdrcrs's Avatar
i was probably gonna do the porting with the head and IM thats on the car now. it will be out of commission for a while but its really no big deal. maybe ill have the shop re grind my cam and knock it all out at once.
i know where to get fuel parts but i cant find any pistons and rods for the RA.
Old Nov 15, 2007 | 05:17 AM
fkdrcrs's Avatar
yeah a friend of mine suggested that too, but that would be the last thing id install.
Old Nov 15, 2007 | 05:19 AM
fkdrcrs's Avatar
would i be able to use wrx injectors for an n/a setup? also would it be worth it to bore my stock fuel rail?
Old Nov 15, 2007 | 05:24 AM
rods "should" be the same as another mitsu engine. search around, it was bumped recently. pistons, just need to get one of ours sent out to one of the major manufacturers. gotta find someone that will work with you on a solution though. it won't be cheap though
on the other hand, RRM may be able to hook you up with whoever is doing their pistons, or at least order them to your spec.
the evo8 fuel rail fits our car, search and you will find that thread. different injectors come from the base wrx and the 350z's.
Old Nov 15, 2007 | 05:28 AM
I wouldn't bore the stock rail, just upgrade. cheap parts from the evo for that, and while you would be the one to determine whether or not you need to upgrade your fuel system yes the wrx injectors would work. there are lots of things you can plan out with a little math, I believe someone has hypothesized that the stock injectors would be ok up to 200hp.
IMO you wouldn't need the rail upgrade for NA. you may need the injectors, it just depends on the duty cycles you see after doing all this engine work. if you decide to nos it you will need injectors though, if not a return-type rail and new pump.
plan plan plan, and then plan some more
Old Nov 15, 2007 | 10:20 AM
fkdrcrs's Avatar
thats exactly what im doing...........PLANNING. i want to make sure that everything is in order for when i begin this. if rrm is still making their turbo kit next May ill go with that, but i want to make sure i have a prepared back up plan.
the pistons sound like more trouble than it might be worth so ill scratch that until a later time.
thanks dan, your always helpful
