04-06 Ralliart Engine/Drivetrain (no forced induction)
Eliminating balance shafts
Old Jun 28, 2008 | 10:38 AM
otter's Avatar
EvoM Administrator
Originally Posted by omgivec
LOL Do i need the kit to do it?
Yes, otherwise oil will spray wildly from your engine. The kits are cheap, only about $30 or so. It's installing them that's a big PITA.
Old Jun 28, 2008 | 03:07 PM
omgivec's Avatar
Thanks otter. Now what i need is some free time to do it lol.
Old Jun 29, 2008 | 10:15 PM
egk-69's Avatar
just cut the stupid belt, that was what I did, and I run 1 year and 4000 miles, with out any problems. Slight improvement in acceleration, very good mod!, and the best is that its free (if you have at least a little experience )
Old Jul 2, 2008 | 11:39 PM
robyn402's Avatar
anyone have any problems so far?
Old Jul 3, 2008 | 12:25 AM
egk-69's Avatar
no till I sold it, beating the hell out of it, I didnt even change the oil for 18 months!! HAHAHAHAHAAHAH LOL!
it was Mobil 1 Full syn., but anyways 18 months and like 6000 miles on it....
Old Jul 3, 2008 | 10:29 AM
robyn402's Avatar
hmmm interesting better acceleration though u say... with no real negitive side effects... wtf is it there for then?
Old Jul 3, 2008 | 10:35 AM
Cow town racer's Avatar
It helps to keep the vibrations down, thats all I know about it.
Old Jul 3, 2008 | 12:45 PM
DangerousDan's Avatar
engine harmonics. need to do some reading if you want to understand anything other than what cowtownracer has said in laymans terms.
to elaborate a little: everything that rotates in the engine must be perfectly balanced. This goes against nature; nothing can be perfect.
If nothing is perfect you have to make do with what you have, and in order to offset vibrations from the revolution of the (mainly anyway) cam and crank shafts balance shafts are used. The balance shafts are turned by belts(egk's diy balance shaft delete ) and directly interfere with vibrations created by the cam and crank sensors. newtons law says for every action there is an equal and opposite reaction. the balance shafts negate that reaction by absorbing the reaction instead of the motor doing so. (a more accurate but less clear way to explain it would be the balance shafts create opposing vibrations to the cam and crank shafts)
there is still a ton of vibration no matter what you do, so they use balance shafts to offset the damaging vibrations that tend to perpetuate themselves (harmonics gets involved here) and use flexible materials in areas that are subject to extreme random vibrations (such as engine mounts) so the car doesn't rattle itself apart (or blow up, depending upon how off balance the internals are ) in a year or so.
that's why the OEM crank pulley is sometimes referred to as the harmonic damper, by the way. the pulley actually has this function built into it in the form of a rubber spacer between the hub and rim of the pulley. vibration produced by the crankshaft is amplified (due to physics laws) by the crank pulley, the rubber surround offsets (not completely, nature isn't perfect) these vibrations.
all in all you would be shortening the life of your engine. anything you do to remove safe guards is going to shorten the life of your engine. that's pretty much a fact of modding your car though, so MORE POWER!!!
Last edited by DangerousDan; Jul 3, 2008 at 12:48 PM. Reason: clarity, if that's possible
Old Jul 3, 2008 | 02:04 PM
robyn402's Avatar
good explanation though...
Old Jul 3, 2008 | 02:55 PM
PR_Mivec's Avatar
a better explanation can not be written of this
Old Jul 3, 2008 | 03:23 PM
egk-69's Avatar
there only in there to eliminate a few vibrations people my not like (I cut the belt and the vibrations added were minimal and I could only feel it on WOT) stupid confort things companies make...
Old Aug 10, 2008 | 10:19 PM
captain150's Avatar
Just read what DD said.
To elaborate slightly, inline 4 cylinders are inherently unbalanced, as are 60 degree V6s (the next most common engine) and American-style V8s. 4 cylinders in particular aren't much better than single cylinder engines.
That's the reason for those huge weights on the crankshafts of 4 bangers (among other engines). Those weights are the most basic and essential vibration-reducing component. Those weights reduce (and almost eliminate) what's called primary imbalance. For reasons I shan't discuss, 4 cylinders (and others) still have what's called secondary imbalance.
Boxer engines (I think both 4 and 6 cylinder types) are inherently balanced, as are inline 6s and V12s. 90 degree V6s may or may not be inherently balanced, I don't remember. Whatever the case may be, 90 degree V6s are quite rare these days.
This wikipedia article is quite thorough, for anyone interested.
http://en.wikipedia.org/wiki/Engine_balance
Also a random fact, Mitsubishi introduced the first balance shafts in a 4 cylinder. This allowed much larger and more powerful 4 cylinder engines. Prior to balance shafts, 4 cylinders HAD to be small, weak and reasonably slow-revving.
My old car had the GM 2.5L iron duke engine. It did not have balance shafts and you sure as hell knew it.
RAPPER8521
Jul 3, 2017 01:06 AM
EvoJoeIX
May 22, 2013 07:25 PM
Rp.cudd
15
Mar 15, 2013 01:50 PM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
SPOOLEDTSiAWD
75
Nov 25, 2007 09:09 AM
