Clutch problem
GDS,
I may just go ahead and try this. There's also a company named Brute Power/perfection clutch that make a CMC for our cars that I think doesn't come with the phucking plate on it!!!! That CMC is built for the Evo as well!!! So it seems there's some truth to this after all.
http://www.perfectionclutch.com/applookup-redirect.html
Part number 350193
Part number 350193
does brute power have a catalogue? i'm not sure they make a clutch for any fwd Lancers. I think he's referring to the master cylinder only.
For us, the evo 8/9 master cylinder works well with aftermarket clutches. My stock one lasted almost 90,000km on an ACT HD pressure plate, and 250,000km total. The evo cmc is worth the ease of installation alone...our stock one is a *****.
should we get a sticky on this b***h? would've helped me immensely if i had seen this before i bought my HDSS clutch from ACT in the winter
edit* - also, magnus performance near my house has an online shop and they are selling evo 8 cmc's for 150USD in case anyone needed it, that's how i got mine
im gonna have tp throw in mine with an OEM TOB next swap, cant let that 500 bucks go to waste, still in very good working condition after the bearing died but it looks like a** full of knicks. Crans how successful have your tranny rebuilds been, if i recall vorrectly you've done at least two for the f5m42, i have a tranny sitting around, it was making a supercjarger like noise. Whirring through all the gears, the mechanic said it was a diff, should i just invest in a new used transmission?
Yeesh
im gonna have tp throw in mine with an OEM TOB next swap, cant let that 500 bucks go to waste, still in very good working condition after the bearing died but it looks like a** full of knicks. Crans how successful have your tranny rebuilds been, if i recall vorrectly you've done at least two for the f5m42, i have a tranny sitting around, it was making a supercjarger like noise. Whirring through all the gears, the mechanic said it was a diff, should i just invest in a new used transmission?well my first rebuild was when I installed my Quaife LSD, second was when the clutch exploded and I had to Frankenstein a transmission together using my original gear set and the junk yard case...then shortly after that I rebuilt the junkyard shafts and then swapped them into the case they originally came in...the tranny I'm currently using came with a completely worn 3rd synchro, and a whiny second gear....the whine is excessive backlash...if every gear does it, the transmission may have been run dry for some time, or it is the diff, or rather the final drive...
the tranny rebuilds are ongoing...my next plan is to repair my original case, rebuild the shafts with new gears and all that, and then reinstall it, and use the current one as a spare...
Kooldino
Nov 5, 2013 11:02 AM
wilbdog
13
Mar 23, 2010 12:05 PM
